Question about Tunturi T60 Folding Treadmill
How do you calibrate a Tunturi T60 treadmill after motor replacement
maxtreadmill
  • 832 Answers
SOURCE: IHAVE A TUNTURI 800 TREADMILL THAT IS ABOUT 18
Call Accell Fitness of North America they are a Tunturi distributor: Call 1-800-388-6887 they should be able to tell whether parts are available for your unit
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have Tunturi J 550 treadmill. I need belt groved
Call Accel Fitness of North America They are the tunturi distributors they have tech support and if parts are available for your unit you may purchase them directly. Tel# 1-800-503-1221
Posted on Mar 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 13 Answers
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Posted on Jul 29, 2010
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Put a Tunturi t60 control motor board back together
What do you want to know .
Send a pic if u like and I will tell you how .
Darren
May 14, 2015 | Tunturi T60 Folding Treadmill
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Tunturi t7 showing error 20 !
this means the treadmills power reading when the treadmill was operating at speeds of 1 miles per hour or less . Excessive amount of power is being demanded from the motor controller for an excessive period of time
Causes:treadmill user (especially a heavier user) is standing on the drive belt.
the drive belt too is badly worn.
brush motor faulty
SCR motor cotroller lekay or shorted drive motor or capacitor
IN short RUN the sotware calibration for diagnostic.
Remedies:Lube the deck belt, determine using AC ammeter for the amount of use the current being drawn by the readmill.Replace the drive motor brushes.or replce the motor controller board. see the block diagram
God bless you
Oct 11, 2012 | Tunturi T70 Treadmill
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
ELEVATION RAISED AND STOPED
pleae RUN inmediately the software caibration for diagnose, troubleshooting, fix it.
LUBE the gear and shaft elevation motor, see the diagram
2) test the elevation motor, see the instruc.
God bless you
Jul 20, 2012 | Tunturi T60 Folding Treadmill
I have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:
LUBE inmediately the machine, the problem is lack of maintenance, maybe you have deck belt worn, that produce enough friction and by consequence shut down the machine.
2) Lube the rollers bearing in according with the instr.manual schedule.
3) Measure the voltage motor, if there are voltage the motor need repair or replace.
4) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
5) Run the software calibration for diagnose, and troubleshooting.
See my personal tips for help.
sincerely. God bless you.
May 07, 2012 | Tunturi T60 Folding Treadmill
The machine just goes into auto calibrating on the screen and beeps constantly. does not stop auto calibrating Just seems unable to cope with any programs to do with hill climbs
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
Feb 17, 2011 | Tunturi T60 Folding Treadmill
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
Jun 18, 2010 | Tunturi T60 Folding Treadmill
Tunturi T60 Folding Treadmill Logo
225 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
