Question about Kitchen Ranges
My gas oven starts, but after about 5 mins. it turns off.
  • 1 more comment
  • joetmidd Sep 13, 2010
    Okay --- I have a manual it is all in spanish. Where do I locate the thermo couple / thermostat/ gas valve. Do I need to pull the oven out? or remove the bottome panel? Can I get an english maual?
    Our model number is : SLIM 90
    I am sorry. I thought i already establised that. It has and operation manual saying it is a Bosch Premium Klasse Top II with another operation manual saying SLIM 90. The second one seems more like and installation manual.
First check the bypass at the thermostat to see if it is blocked with old grease (from cooking) If no grease, replace your thermocoupler that is fitted next to the oven burner.
Posted on Sep 14, 2010
  • Kitchen Ranges Master
  • 1,711 Answers
There are two possible faults
First the thermocouple need replace since it cannot keep the gas valve open when is heated for long time.
Second possibility is the thermostat need to be replaced.
You can bypass the thermostat by connecting the two wires together if the burner is continually burn then is the thermostat either you need a new thermocouple.
There is a very small chance that the problem is the gas valve but you should try the above first.
Posted on Sep 13, 2010
  • espressonist
    espressonist Sep 13, 2010
    Thermostat is the knob with temperatures on it and includes a probe which a thin copper pipe wire located in the internal part of the oven and is the difficult part when replacing the thermostat.
    Gas valve and thermocouple are located on the bottom of the oven and you can find them by removing the bottom panel pan.
    For manual let us have the brand and model of your oven so we can see what we can find for you.
  • espressonist
    model slim 90 but which brand
When starting the oven there is a 3-5 min delay before the oven will ignite.any ideas what might be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 01, 2011 | Bosch HGS256UC Gas Kitchen Range
I turn the oven on and set the temperature 5 mins later I check on the food and the oven has turned itself off and displays stop on the LED.
Is it gas or electric? If it is gas it sounds like the ignitor is bad keeping the oven from heating up. Does it preheat and then go off or never heat up?
Feb 25, 2011 | Ovens
When I turn the oven on it preheats for about 5 mins then starts beeping. The display says "F2". I unplug it for 5 mins and replug it in. Then I hit "oven" and "start" and it...
this is a shorted oven probe fault code. you will need to replace the oven temp sensor.
The part number should be 8273902 and it can cost about 76.00 dollars from a local parts store in your home town.
I hope this helps.
Happy New Year and thanks for choosing fixya.
Jan 02, 2011 | Whirlpool GS460 Gas Kitchen Range
Oven takes 3 or 5 min to ignite igniter comes
you may need tp replace the FFD in the oven.
Jan 02, 2010 | Kitchen Ranges
Oven doesnt work
you have a short most likely try to unplug for about two mins to let reset
Jun 21, 2009 | New World G70m Gas Double Oven
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Stove 720g Grill
HI YOU MIGHT HAVE A SAFETY THERMOSTAT THAT COULD BE FAULTY.BEST YOU HAVE A TECH TO HAVE A LOOK AND REPAIR.
GOOD LUCK.PLEASE RATE THE SERVICE.
MOHAMED
Sep 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Oven does mot work
F-7 on the GE is a touch pad error, all you can do is replace the whole touchpad. You can try shutting the power off at the breaker leave off for 5 min at least. turn the power back on sometimes this will get rid of it for a time.
Feb 23, 2008 | GE JGRP17 Gas Single Oven
Cleaning the over
Try pressing and holding the cancel button for at least 5 secs. Wait a few mins. Something different should display on the display panel. The door should unlock after a couple of minutes.
Dec 25, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
