Question about Harley Davidson 426290 AM/FM Radio
I need a dual fm antenna switch to select from one antenna to the other for a fm radio. Thought where to find one?
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Mouser or Allied electronics
Posted on Oct 17, 2010
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
Feedback through fm radio
try using a seperate ant for ur radios
Jul 20, 2010 | Radio Communications
Can an on-off switch in car antenna help FM transmitter sound ?
  • they are dependent upon the antenna. best thing to do if u want a to spent the time and money to do that would be to install a new stereo witha AUX plugin instead of your FM transmitter
Dec 02, 2009 | Car Audio & Video
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Harley Davidson 426290 AM/FM Radio Logo
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
