Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
I don't have the starter cover i was working on the unit and in emergency i had to go to work for 8 months when i came back the parts were missing
Posted on Oct 24, 2014
    President:
  • McCulloch Master
  • 1,388 Answers
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Posted on Sep 13, 2010
Starter pull rope does not rewind spring broke how to tear down
How to Rewind Recoil Starter Spring Quick Fix This page also has videos explaining how to remove and replace the cover with recoil spring.
Sep 01, 2014 | Polaris Scrambler Men's Mountain Bike
Mcculloch ms4018av
There is a pawl that engages the recoil starter with the power take off end of the engine. It is probably sticking. If you remove the recoil starter and pull the cord you should see the pawl swing out, then retract when the cord is released. If you take it apart clean out all the gummy grit and give sliding parts a coat of lubriplate which is a light, waterproof lubricant you can purchase in a small tube just about anywhere.
Oct 23, 2013 | Garden
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Starter cord replacement
Here are the basic steps:
Prepair the new starter rope (about 5 feet of good qualty starter rope size 5.5) by burning the end and shaping into a point and tie a temp knot on the other end. Use a rag to shape the end because it will be very hot. Remove the old rope and align the hole in the spool with the hole on the starter cover and practice incerting the rope thru the guide hole on the cover into hole on the spool . This will be the final action after you wind the spool. You should be able to hold the spool and insert the rope thru both holes and tie a knot while holding the spool in a wound state. Once you have mastered incerting the rope thru both holes and tying a knot you are ready. Now begin.
Wind the spool in the same direction that the spool turns when you pull the rope. You must wind in the correct direction or you may bend the spring out of shape. The spool will begin to tighten as you wind and will eventually stop turning when the spring is fully wound. Once fully wound unwind spool one full turn and stop when hole on spool aligns with hole in cover. Now insert rope as practiced thru both holes and tie knot with free hand or have helping hand. Once knot is tied slowly let spool take rope in untill no more will go in or you reach temp knot. Now tie pull handle and you are done. Good luck.
Jul 17, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
My lawnmower starter pull rope broke and i wanted to replace it myself to the something i can do myself. It is a craftsman 7.0 horsepower push lawn mower. Any body with step by step instructions and what...
The biggest thing you need is time. There are no special tools required but it sure helps of there are 2 people available to perform this task.
You will have to remove the recoil assy if it can be removed without the air shroud or the entire upper engine cover / air shroud with the recoil. This procedure should be performed by 2 people that are NOT distracted.
First you will have to have a replacement rope. Burn the end of the new rope your going to install into the spool and pinch it so that the end is smaller than the rope and pointed. Install the pull handle on the new rope and make sure there is a good single knot on the end of the rope that goes into the pull handle.
Next you will have to remove all pieces of the old starter rope.
Then you have to pre-wind the spring of the recoil so that if you were to allow it to turn, it would turn in a direction that would pull the starter rope onto the recoil spool.
NOTE: Once the pre-wind is done if anyone lets go of the spool it can DAMAGE the recoil spring!
When your prewinding... Turn the spool until snugs and does not want to move anymore. Then back off the spool until the rope KNOT hole is aligned with the recoil rope guide.
Thread the new rope through recoil rope guide and into the KNOT hole in the spool. (Ice pick scribe jewlers screwdriver... will be required to pull the new rope up and out through the knot hole. Then TIE a KNOT in the bitter end of the rope and pull the knot into the knot hole on the spool.
FINALLY have 2nd person release the spool and it will rewind onto the spool.
Install the recoil / air shroud.
Thanks for using FixYa.
Kelly
Feb 28, 2010 | YouTube Videos
No 120V output
Please test the following and get back to us. Repace the receptical with one from a electrial store have found that many of them turn out to be bad once you replace it retest for voltage. If it still has no voltage then get back to me by posting a responce here to this question.
Jul 14, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
608 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
