Question about Eddie Bauer PE702 Portable DVD Player
Test1 test
Posted on May 15, 2008
My frigidaire GLD2250 dishwasher will not cycle no lights, only hums
see the w. diagram for test
1) test the switch door, if these switch is defective will not close the starting relais, for main motor. No cycle, and anything.
God bless you
May 09, 2012 | Frigidaire Dishwashers
My LG dishwasher LD-2040WH washed and as soon as the element goes on it switches off by itself. I put it on the gentle cycle and then it switch off and now there is nothing going on it is completely dead...
1) Test the switch door for defective, this switch can be open or defective and can be open the starting relais and turning off the main motor.
2) Timer: test for defective, clean contact, repair wires loose, broken, or burn.
May 09, 2012 | Whirlpool 24 in. DU940QWD Built-in...
Reset button seems to be stuck down and run out of hot water to soon
If I understand correctly, you have an electric water heater.
The water heater is dual element and has 2 access panels on water heater.
You run out of hot water quickly.
And the reset is stuck down.
First of all, if the reset button is tripped, the water heater will produce NO hot water.
The reset, or ECO (electricity cut off), is designed to cut off all power to water heater.
So if you have some hot water, then ECO reset is fine.
The thermostat may be bad, but the ECO is fine
Next in line:
If your upper element is burned out, then the water heater will not make any hot water.
So if you have some hot water, that tells us the upper element is working.
The three remaining suspects are upper thermostat, lower thermostat, lower element
Let's test the lower element.
Turn off the power.
Remove both wires from lower element.
Test across both screws with a continuity tester.
The continuity tester has a battery and when light comes on, it says the circuit is complete.
Test1) Test across both screws on lower element with continuity tester.
If the light comes on then the element is good so far, but element has to pass one more test.
Test2) Test each screw on element to any bare metal part of water heater.
If the light does NOT come on with the second test, then element is good.
Element has to pass both tests. Light ON first test. Light OFF second test. Then element is probably good. This is not a fail-proof test but it is a good indicator.
I'm betting the lower element is burned out and you need to replace lower element. And you may need to vacuum out the sediment.
Now if lower element is good, then the easiest thing is to do is replace both thermostats. After replacing both thermostats, the water heater will probably work. If there is still a problem, then the lower element was not as good as the test showed, and it should be replaced also.
If you are still having a problem, answer back and we'll give you more details.
Oct 23, 2010 | Reliance & Electric Water Heaters
Details on dual core issue. Hi, As you are aware, we are using WT12 Bluetooth Module on PC based system, which receives data from an embedded system, working together with a bluetooth dongle. The system...
You have gone on at length describing your problem, however you have failed to indicate what the Operating System is? I assume it is XP, and prey it is not Vista or Win 7? Or worse a 64bit version of those? Anyway, I sincerely doubt that the fact that the PC is "Dual Core" has anything at all to do with anything? Most likely it has to do with the transport driver layers and the Widcomm Bluetooth drivers almost without a doubt. Bluetooth whilst a great platform, is indeed fraught with problems.. It doesn't even work all that reliably on Cell Phones and Headsets, that it was designed for. Packet loss and corruption invariably is due to outside interference and, depending on Operating System, bad USB handling and interfacing, what with USB & Bluetooth together we always have problems. One way is too mitigate problems is to increase the Output Power of the Transmitter and buffer and error check at the receive end. Again I would try "Other" Bluetooth "Stack" such as say, Bluesoleil or Toshiba's one. This project indeed sounds like a challenge. I also think that one shouldn't be to fixated on things like Dual Core's & P4's and the like, I have never had an issue, such as you describe, with processors, the problem I am sure is elsewhere, use Occams razor.. and do not get side tracked. Good luck, If you were in NZ I would get hands on with you.. could be entertaining challenge to say the least. Good Luck
Feb 24, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Application Watcher Main Thread?
Friends, this I got from allaboutsymbian website. And I already try the Test1 and it works!!!
Hope this could be much of help......
I had the exact same problem and have solved it by updating the firmware and reloading my settings from at saved bile, but it is rather time consuming.
The solution by deleting all the messages in the inbox worked perfectly fine smile.gif
Though nothing haapend when i only deleted the outbox and sent.
I assume that the problem is caused by the message server (the small program handleing you enter to send and read messages)
I descuvered that when my phone was put into offline mode, and re-entering to normal mode , I could not open the message server.
After deleting all messages this problem has been resolved aswell.
Maybe the message server is having problem handleing to many messages.
The amount of space left on my phone was not a problem eather, arround 30 M and the insert card was empty.
but i had over 1300 messages in my inb ox when the problem started occuring.
If any ojne else is experiencing this problem, pleace keep on debugging and tributed with more result.
This will make it easyer to conclude on the results and finally determine why it is happening, based on when.
Test1 : (Is the issue resolved only when inbox being emptyed)
Here is what you do :
1. Delete all you messages - 1 in your inbox,
2. Restart the phone,
3. Send an sms to yourself.
4. Write a reply on this threat weather youi got the message or not.
if it is not resolved. please continue with 2. test
Test2 : (Is this allways resolved by emptying the indbox)
1. Delete ALL you messages in the inbox
If the problem is stille not resolved then you have to reset the phone.
Test 3.
First of all, you must save all you phone settings, phonebook sms(despite you just deleted them all, save it anyways!) phone settings. etc.
and then reset it.
1. Save all files
2 Reset you phone by typing in *#7370#.
3. Restart the phone,
4. Send an sms to yourself.
5. Write a reply on this threat weather youi got the message or not.
If this works, then restore one of the save configurations at a time and test weather it still works.
Aug 09, 2008 | Sony Ericsson P1i
Multiple video in html
just add a link to it on the page as if you were sending it to download
Dec 31, 2007 | Microsoft Windows XP Professional With...
Eddie Bauer PE702 Portable DVD Player Logo
66 people viewed this question
Top Eddie Bauer Televison & Video Experts
Are you an Eddie Bauer Televison and Video Expert? Answer questions, earn points and help others
