Question about Marantz SR8001
Hi, my Marantz sr8001 is on standby mode, can you show me how to reset standby mode. Thanks
  • Hello there.
    Since I have my self the same issue with both an SR6001 & SR8001 AV receivers, I know exactly what you want to do.
    I assume by asking you want to reset the Marantz you mean this has went into Stand By mode, after a message "Protection" appeared on the screen of the machine. Is this correct? If yes, you cannot turn on the machine, and there is absolutely no response after pressing any button on the remote.
    Please give me detailed info and I will tell you what to do in order to get rid of this problems once for all.
    Best Regards
Mine is doing the exact same thing! All I want to do is get it OUT of standby mode!
Posted on Jan 07, 2011
Marantz sr3053 stuck in headphone mode
Usually the headphone jack is like a mechanical switch and it's probably just not making a good connection inside. Use the correct size headphone jack and insert it then remove it maybe a couple of times and see if that fixes it.
Apr 18, 2014 | Marantz SR8001
Harman Kardon AVR 350, Unit powers off into standby mode after a few seconds. Removed all connections and wires, problem persists. Weirdly enough, if I keep pressing the source button, the unit stays on....
It needs to be serviced. Bad caps, resistors, & possibly a transistor or two. Not an unbearable repair, but you can count on it being 100-175 depending on the shop. You followed all the troubleshooting you could without opening the unit.
Oct 02, 2013 | Marantz SR8001
How can i remove standby mode marantz sr3053
Resolve the issue.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 17, 2011 | Marantz SR8001
I have one Amp;SR4003.if i on the amp;its showing standby light only.which stage defective.pls give me ans; Regards ...
hi,
check the power supply voltages 5v, +-15v. also check the power on relay driver side. also check is there is any dry soldering in power supply stage. check the output amplifiers is there is any transistor faulty. for any further assistance feel free to contact through fixya.
ok
Dec 23, 2010 | Marantz SR4003 Receiver
For no reason I know of, my Marantz SR8001 will not come on and the display will not light up. It will not respond to activation using the power button on the display panel, or the power activator on the...
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Oct 14, 2010 | Marantz SR8001
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
What type of speaker wire terminals does the Marantz sr8001 allow?
Hello there.
These are blind posts (i.e the unscrew back) but will not allow you to unscrew them fully to use spades.
Only bananas (of any type) and bare wire (do not recommend it).
I own the same SR and faced many issues (even going into "protection mode") due to bad quality binding posts used on this machine.
For any clarifications (specific type of terminals) let me know.
Evangelos
Oct 07, 2009 | Marantz SR8001
Marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Aug 07, 2009 | Marantz SR8001
Shuts off !!
check your output stage
Nov 18, 2007 | Marantz SR8001
Marantz SR8001 Logo
867 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
