Question about JVC RX-817V
I own a JVC RX-817V Audio/Video Control Receiver its pretty old now, and uses copper wires to run sound to the speakers. The problem is that only one set of the output clamps actually puts out any sound - the others put out sound so low you can barely hear it. I was wondering if this was a common problem for this model with an easy fix or if it's pretty much done for? I have 4 speakers to hook up so hope to hear from someone soon!
sparky1500
  • 1066 Answers
SOURCE: No subwoofer output
yes, you do have to set up the sub output in the reciever.
Posted on May 17, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Yamaha RX-V363
There is likely a static charge (voltage / difference of potential) between the the receiver and the TV.
They should have their grounds tied together. This should be covered in your owner's manuals.
In some cases, there may also be a stray voltage on the cable line's ground. If grounding the two together doesn't work, you may want to call the cable company (or you or a friend may be able) to check the cable line for a stray voltage or bad ground.
Posted on Nov 08, 2008
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
lynchms
  • 93 Answers
SOURCE: JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
I have a JVC Receiver that I'm trying to hook a
"[A] set of Sony Speakers" is meaningless. What model(s)? If they're part of an all-in-one system they may not be suitable for the JVC.
Manuals exist for everything. Read them.
http://www.retrevo.com/support/JVC-RX-5052S-Receivers-manual/id/315ci175/t/2/
This receiver is designed for standard commonly available 8-ohm (nominal) speakers that connect with common stripped end lamp cord or speaker wire.
Sep 03, 2011 | JVC Audio/video Receiver Rx-5052s -...
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Can my rx-817v home theater system be connected to an ipod or is it too old?
Any iPod or MP3 player at its most basic level is just an ordinary analog audio source.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
You'll still have tyo navigate the music on the iPod. Life is cruel like that.
Aug 05, 2011 | JVC RX-817V
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
My JVC receiver won't play my left front speaker. The right one seems to work fine but when I plug in the left it is virtually silent. i too have had a few "overload" incidents and am running two JBL 8...
swap the wires around to see if the right speaker will give sound on the left channel. If it does, the it's a blown left speaker. If you don't get sound out the right one either, then the left channel ouput has a bad capacitor somewhere in it.
Jul 06, 2009 | JVC RX-6010V Receiver
Antenna hook up and weak sound
i had the same problem and i gave up on the adapters, i ended up stripping a peice of 14 gauge speaker wire and twisted it together slipped it on the hole and it worked better than anything yet, been running clear as day for a year and half now
Jan 02, 2009 | JVC RX-6000V Receiver
JVC RX-817V Logo
529 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
