Question about Akai PT5492S 54" Rear Projection Television
I have an AKAI 5492s projection TV. It's red and green color is over riding everything. any help would be appreciated.
SOURCE: Akai PT4298HD Rear Projection Television Problem
THE PROBLEM IS A MAIN SIGNAL PCB PART A94-00139A , YOU MIGHT AS WELL BUY A NEW TV, THE TV YOU PURCHASED WAS A CHEAP TV AND THOSE DONT LAST AND PARTS ARE HARD TO FIND
Posted on Nov 14, 2007
SOURCE: Akai 55
I used" Silerado 1st" solution. I have an Akai pt5598hdix/sms.
I had ghosting.Like 3 colors side by side.
Silerado said with TV off press "mute,1,8,2" then TV on.
I didn't see anything like a menu.He warned to write down any setting you saw before you change anything.But for me nothing came up. So as he said the next step try with TV "on" press "Mute,1,8,3" this is another set of adjustments for finer detail. I lined/overlapped all the lines up or down or side to side useing the channel and the volume buttons and then held the enter button down until the TV flashed 3 times.Then I shut it off and when I turned it back on It was perfect.
Thomas Fitzgibbon
Posted on Mar 30, 2008
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
  • 1779 Answers
SOURCE: My Akai Rear Projection Televison has a good
I'd like you to turn the color all the way down and let me know if the over-all picture looks Black&White or as we call it gray. Did this just happen or has it been changing over time?
Posted on Feb 28, 2009
repairtech99
  • 767 Answers
SOURCE: double vision w/ red & green tint
This is a comon problem
There are two large convergance chip's
the are failing .Replaceing them will
corect the problem . The chip range
in cost from 16,00-30.00 .There cheap,
so dont let the shop over charge you
for parts when and if you decide to
repair it.
Posted on Jul 03, 2009
Akai pt 5492s. Where can I buy these CRT tubes?
That television is 14 years old and you are most likely out of luck.
Apr 04, 2016 | Akai Televison & Video
I have an akai 55" projection tv and the top and bottom of the picture is bowed with green and red colors which makes it look like a 3-D movie. how can i fix this problem and what will it cost to fix and...
The tv have a problems known as a convergence problems,it dead.Yes,try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung use the same tv convergence board.The board around $200.
Sep 09, 2010 | Akai PT5598HD 55" Rear Projection...
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Toshiba 50h81 2001 rear projection hdtv ONLY SHOWS GREEN! PLEASE HELP!
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Toshiba 50H81 50" Rear Projection...
PT5598HDI Wiring Problem
the red wire will go somewhere to the right side near the High Voltage section. The green wire is probably antenna. DO NOT get them crossed...
Question. what connector if any is attached? The board will usually have a pin sticking up that is marked...
Jul 13, 2008 | Akai PT5598HD 55" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Colors red and green overlap
Covergence is off... Check convergence and see which color will not move in the convergence settings... That is the STK that needs to be changed out...
May 24, 2007 | Akai PT5492S 54" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
29 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
