Question about Grundig GU19WDT 19 in. LCD TV
My grundig gu19wdv4 tv cant find any freeview channels and all the leads are plugged in why wont it work :s
  • 476 Answers
SOURCE: cant work my freeview
The [A/D] button on the remote control switches between analogue and dgitial TV.
If this doesn't work you can restore the TV to factory settings as follows:
Press and hold the [Menu] button on the TV (NOT on the remote)
The picture / sound / features menu will appear.
Continue to hold until this menu clears.
Release the [Menu] button and wait for about 90 seconds.
The TV will go blank and eventually return to the original install menu.
Install the TV as you did from new.
This will clear ALL analogue and digital TV channels and install again from scratch.
This should be used if the TV ever freezes on digital, or if any of the channels appear in the wrong place or not at all.
Posted on May 08, 2008
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
I have a Sharp Aquos 26-D44E. The factory preset PIN on this one is 1234.
Posted on Feb 10, 2009
rulds2008
  • 3866 Answers
SOURCE: recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 17, 2009
SOURCE: Freeview has locked on one channel and won't retune
Used the solution of another user and it finally worked after a few attempts
Posted on Oct 02, 2009
  • 159 Answers
SOURCE: i have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Posted on Sep 26, 2011
I have grundig lenaro 32"tv
Mar 30, 2011 | Grundig Televison & Video
Why wont my tv tune in the digital chanels using just an Ariel, its a Grundig about 6 years old.
Unless you have built in freeview then you won't be able to receive digital channels. Sounds like that's the problem here.
You'll need to buy a separate freeview box, you can get a basic model for ~£20.
Mar 01, 2011 | Televison & Video
I can not set up my freeview on my samsung 52 inch LCD can u help me step by step as I hav no instructions thanks
Plug your aerial into the freeview box. Connect a scart lead from the freeview box to your TV and switch on.
The freeview box, if new, will search for channels itself and as your TV will recognise that it is plugged in, will auto switch to the freeview box.
If it is not new, select menu on the freeview box and follow the instructions for tuning.
There is nothing to tune on your TV as you are using a scart lead.
Hope that helps.
Nov 14, 2010 | Televison & Video
I cant get my durabrand freeview box to work.
i have pluged in all the plugs to be in and all in the right places but i have no sound but im getting a picture ??????
Nov 22, 2009 | Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Grundig GU19WDT 19 in. LCD TV Logo
75 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
