Question about LG Washing Machines
While using the machine and during spin operation, the machine dispays the error message OE : drainage trouble, how can i fix this issue
  • 15,935 Answers
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Getting OE error in my LG Tromm washer
Can be down to
kink in drainage hose
water drain pump
or an often overlooked drainage problem ...believ it or not can be a malfunctioning heater in the machine...
hope this points you in the right direction..
Apr 15, 2014 | Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
WATER WILL NOT DRAIN OR SPIN
OE is inded a drainage error.
From what you describe it is most likely that the drain motor is not working properly due to a loose electrical connection or bad motor itself. This is not that easy to verify since it requires some machine moving and disassembly to get at it.
I can give you further instructions if you like...
If your machine is still under warranty you should call someone in for service.
Aug 06, 2008 | LG WM1815CS Front Load Washer
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Washing Machines Logo
57 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
