Question about Roper Dryers
Low heat from roper clothes drier - Roper Dryers
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 14, 2010
FGR231ASY GAS DRYER BURNS FLEESE MATERIAL CLOTHING WHY
Hello my name is George,
I was wondering if the dryer was just burning fleece or all of your clothes. Fleece is a very delicate material, and should be dried on low temp or delicate depending on your drier. Driers are thermally protected inside with various parts. If the drier is getting to hot one of these would have caused the drier to stop heating. If the drier is burning all the clothes and not just the fleece I would recommend having a technician come out and check it as this could be a hazard for you and your family.
Oct 26, 2012 | Dryers
I have a Roper drier, Model # EL5030VW0 Recently we put too much into the drier and it stopped tumbling, but there is still heat. We suspect the belt went wrong. How to open the cabinet and examine the...
here is a blow up of that model you might have to copy and paste link hope this helpshttp://www.partselect.ca/ModelFrames.aspx?ModelID=586816&ModelNum=el5030vw0&mfgModelNum=&ManufactureID=3&Selected=6QLYC5ZY&Position=0&mfg=Whirlpool&Type=&Mark=0
Feb 27, 2011 | Roper Dryers
Drier over heats and shuts off. I can dry on "air dry" or very low temperatures. I can only put a couple of pieces of clothing in drier or it will over heat.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Dryers
Dryer spins and heats but clothes are still damp. What could be causing this?
I thnk you have a clogged exhaust. Pull the drier out and insure clean ducts from the machine to the out of doors vent.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Roper REX4634KQ Electric Dryer
My roper dryer is spinning my electric meter like a top I replaced the heating unit but problem is still there on fluff dry no heat the meter crawls but low or high heat and the meter spins like atop
I am assuming that your talking about how much energy your using. When the unit runs on full heat, your electric meter will spin as you say like a top, this is quite normal. Electric dryers use tremendous amount of energy. Going on fluff your using just the normal 120v and not pulling many amps to run the dryer. However with the unit on high your pulling more amps and are now drawing 240v to operate your unit.
If your clothes are drying than it is not the heating unit.
If your concern is the amount of energy expended, there is always the old clothes line, which is energy efficient and if you live in a part of the world where the air is clean your clothes will smell fresher than if it came from a dryer.
Oct 11, 2009 | Roper REX4634KQ Electric Dryer
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
57 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
