Question about Sharp ll-m17w1u 17" Flat Panel LCD Monitor
My monitor is black but it has sound i could hear the tv programs, just not see it. what could be the problem
    Problem Solver:
  • 3 Answers
CHECK TO ENSURE THAT ALL CABLES ARE IN TIGHT AND CORRECT, ENSURING THAT WHATEVER TYPE OF CABLES UR USING ARE IN THE RIGHT PLACE.
Posted on Sep 13, 2010
Sound but no picture
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
Monitor makes a cracking frying sound as it booted up the screen would flicker and then it went black. never come on again
The bulb in those older Monitors dont last too long. Many times whenever you hear that sound its like the tungsten filament burning out or breaking. That's the crackling sound you hear as it boots up. My suggestion would be to get another monitor at this point in time.
Nov 19, 2009 | Proview Computers & Internet
Dell B130 laptop boots up and you can hear all the boot up sounds, however nothing shows on the monitor. It's completley black.
connect to a desktop monitor if u see the screen
change the output screen (tv,lcd) then unplug the monitor if the problem not solved
there is a problem on lcd ,lcd cable or vga adapter
Aug 09, 2009 | Computers & Internet
My samsung 19" lcd tv comes on for a few seconds then the screen goes black.I can still hear the sound.Any ideas thanks Mine does the same thing T220 syncmaster, updated the video card drivers. It has to...
Call them as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all.
May 30, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Very Poor Sound level on ASUS VW223T monitor
check to make sure you have the proper drivers for the monitor.
May 18, 2009 | ASUS VW223T 22in 16:10 5ms LCD Monitor...
TV pop and screen is black but I still have sound.
check your vedio transistor colector voltage is above 60 v
Apr 11, 2009 | RCA Televison & Video
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Sharp ll-m17w1u 17" Flat Panel LCD Monitor Logo
75 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
