Question about Splendide 2100 Vented Washer-Dryer
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
    Problem Solver:
  • 5 Answers
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Posted on Sep 15, 2010
Cycle selector knob clicks forward
PDF]Repair Manual - Splendide
www.splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
Sep 19, 2015 | Splendide 2000S Front Load Washer / Dryer
New tvm63x splendide. Dryer stops and restarts during drying cycle. What could be causing this? Thanks.
Check for a lint build up in the vent hose. Too much will trigger a sensor in the dryer to shut off to prevent a fire.
Nov 19, 2014 | Splendide Washing Machines
What might cause a flashing PF code midway through a cycle? Circuit breaker is fine. Any advice greatly appreciated.
Stop trying to restart it! There is obviously a fault so check your manual. If not in there contact Manufacturer or service agent.
Aug 10, 2014 | Frigidaire Dishwashers
Splendide 2000 will not spin water out
bad pump on bottom back or board see if voltage to pump motor
Jul 29, 2012 | Splendide RV Motorhome Laundry Appliance...
Lock door blinking along with the low heat pre-wash also
I just had the same problem. I called splendide. First thing they asked me was if this was happening when I was trying to dry. And, it was. I was told lint clog and that there is a cycle you can run to hopefully clear it. Below is the instructional e-mail they sent immediately. Love the company - tech service on the phone is wonderful. :)
e-mail from splendide:
Run the unit without clothes and with the dry time off on cycle # 11. When the water stops entering the unit push and hold the start button until all the lights come on then release the button. Next, move the cycle knob to cycle # 2 and press the start button once (do not hold) then let it run through that complete cycle.
Nov 10, 2010 | Splendide 2100XC
We bought a used motorhome with a Splendide 2100 w/d combo. It does not dry the clothes, but washes fine. There was no manual on this appliance, so don't know how to find out the problem. Can you help?...
Your heating element could be out. This could be just a bad element or if you don't hear the fan come in the the dry cycle, the fan probably failed and caused the element to burn out. If your clothes are getting warm but not drying completely then you need to check your exhaust hose and make sure it is not clogged with lint.
Jul 13, 2009 | Splendide 2100 Vented Washer-Dryer
WD200S overfills with water
Sounds like the switch that detects the water level is malfuntioning, this can be caused by one of several reasons.
I assume that the water stops running in if you stop the m/c, if it does not, then you have a faulty water inlet valve, which you would have to replace.
I think you neede to call an engineer.
Hope this helps.
Please leave feedeback.
Dec 07, 2008 | Splendide 2000S Vented Washer/Dryer
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Splendide 2100 Vented Washer-Dryer Logo
335 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
