Question about Microwave Ovens
Under microwave lamp burned out. after changing the lamp the lower row of buttones labeled "Selection buttons" do not work. these features include the vent, light under the microwave amd the turntable speed do not work. everything else works fine.
  • 2,299 Answers
When you changed the light, you must have shorted it. There is a small glass 20 amp fuse that is blown. You have to disassemble the microwave to change the fuse. Unlplugh the microwave and take the top cover off. Where the cord goes into the microwave, there is a fuse there. You can get a new one at any hardware store.
Posted on Sep 13, 2010
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Forgot my childproof code now i cant use my microwave how can i get a new one
Many microwave CHILD LOCK features are activated / disabled by repeatedly pressing one of the function buttons or by holding it down for about 5 seconds.
Try pressing the STOP / CANCEL button 3 or 4 times in a row to see if you can the CHILD LOCK off.
If that doesn't work, also try holding down that button down for 5 seconds.
Try these same two procedures on some of the other buttons as well like the TIMER button, or the START button, or the CLOCK button.
Your best bet however would be to include the brand and model number with your question next time and then we will be able to locate the exact instructions for you.
I hope this was helpful.
Good luck and take care.
Joe.
Dec 14, 2011 | Microwave Ovens
Panasonic microwave genius 1300watt - can unlock child safe
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/NNSD688S.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions and illustrations on how to operate the CHILD LOCK feature.
Basically you just push the START button 3 times in a row TO ENABLE the child lock.
And press the STOP / RESET button 3 times in a row TO DISABLE that feature.
I truly hope that was helpful to you.
Some newer models require you to push those same buttons 4 times in a row instead in order to operate that feature so you can try that as well.
Joe.
Oct 23, 2011 | Microwave Ovens
How can i unlock microwave child safe guard
Joe.
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
Describe your Whirlpool JKP90B0M1BB Micro/Wall Oven combo/ doesn'
Sounds like the turntable motor is burned out or you may need a new coupler which is a plastic piece that sits on the motor shaft under the round glass tray. There is no button to make this work, it should rotate automatically when you select your time.
Jan 24, 2010 | Microwave Ovens
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave
Having the brand and model will help us point you to the parts supplier so you can buy a new keypad.
Please post back.
Oct 23, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
