Question about Vizio L32 32 in. LCD HDTV
No channels in master list on screen?? - Vizio L32 32 in. LCD HDTV
2 Suggested Answers
terrydovre
  • 181 Answers
SOURCE: How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Posted on Oct 09, 2012
No channels in master list is all that will appear on the screen.
Main system control memory IC fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 22, 2015 | Vizio XVT553SV 55 in. LCD TV
Screen reads "no channels in master list"
You may have to do a 'search' for local channels in either cable or on-air mode. It is in the set up screen.
Apr 27, 2015 | Vizio Televison & Video
My screen shows no channel in master list
mine doesn't either, I use my satellite remote and use the program guide to select the channel I want to watch
Oct 16, 2014 | Vizio Televison & Video
Is there any way to reset an rca j32l637 tv without the master remote? its stuck on channel 3 and stays on but then it cuts off and on if u try to change the volume or change the channel then stays on
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Televison & Video
Auto Channel Search
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Uverse says no channels in master list
Do resetting and go for auto scan. If the channels are not stored, there is something wrong with the memory chip inside.
Jul 29, 2012 | Vizio Televison & Video
No channels in Master List message on Vizio xvt3d554sv with Dish Network Satellite...what to do?
I had this same problem. My TV had sound and the lights were on but no picture. The screen said "No Channels in Master List."Here is how I fixed it:1) I made sure that my Dish Remote was on the TV mode (when pressing down buttons, the TV button would light up).2) Once that was confirmed, I pressed 03 to ensure I was on Channel 3.3) (this was the hardest part!) I found the remote that came with the TV. I never use it so it was hard to find...4) I pressed the Input button and selected the correct Satellite option. On my TV, that option is: "HDMI-1 Satellite"5) The picture was restored!
Aug 19, 2011 | Vizio L37 Television
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
The screen has a message "No channel in Master List" on it. There is no picture or sound.
tv is on the wrong input, just press the input button on the remote or the tv that should fix it for ya
Jun 08, 2010 | Vizio P42HD Television
Vizio L32 32 in. LCD HDTV Logo
2,097 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
