Question about Mitsubishi WD-65731 65" HDTV
Cant get my ipod touch to play when using my special audio cables i thought it was plug n play
  • Mitsubishi Master
  • 8,457 Answers
Yes,if ur ipot touch is have plug and play and video capability.Use the HDMI cable.Plug the HDMI cable in one side to the ipot to the USB port hub,the other side to the tv USB port hub.The ipot should,work fine.
Posted on Sep 13, 2010
How do I play my iPod touch through my 55" Samsumg led 3d series 8 tv?
You need a cable, either a headphone jack to red/white (audio), or a special headphone jack with yellow (video) and red/white (audio). They look like this: Apple Component AV Cable
Oct 03, 2010 | Samsung Televison & Video
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
I am trying to hook up my Yamaha Universal Dock YDS-11 for my iPod touch into my Yamaha HTR 5830 Amp but there is not where to plug it into. Do I need another type of cables to do this.
Hi, I'm afraid that your receiver doesn't support YDS-11. You can check it at yamaha site. This dock uses special cable and special connector on the receiver (which yours doesn't have).
So the only way to connect your iPod to receiver is via analog audio output (jack connector on the iPod).
Jan 29, 2010 | Yamaha HTR-5830 Receiver
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Ipod touch says its disabled
Use the cable included with your iPod touch to connect the device with your computer. Plug the fat end into your iPod touch and the longer end into your computer.
Jun 06, 2009 | Apple iPod touch
Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
May 08, 2009 | Car Audio & Video
Ipod classic video
You need a special 1/8" cord for video output. For example the standard 1/8" cord has 2 black rings on the 1/8 plug, each ring is a channel one for left side and one for right side. You need an 1/8 cable that has 3 rings on the plug, 1 for video, 2 for Left and right audio channels. It dosen't have to be an IPOD brand cable it just needs the 3 black rings.
Good Luck
Jun 27, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
Connecting ipod to yamaha A/V receiver
To see video output on your televison, you need one of hte following versions of the Ipod:
  • iPod touch
  • iPhone (software version 1.1.1 or later required)
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod with color display (iPod photo)
When you plug the cord into your Audio receiver, the Ipod is only sending audio to the receiver. For your iPod to send video output to your television, you will need to buy an AV cable for your tv. Here is the link to Apple's website where you can view the A/V cables that will allow you to watch video on your television. Here it is
Apr 13, 2008 | Yamaha RX-V661 Receiver
Mitsubishi WD-65731 65" HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
