Question about Siemens Hammering
Have a 30A breaker and blowing fuses 2 fuses blk wire on top wh on bottom wuts wrong
  • 56 Answers
What does this circuit breaker control?
Posted on Sep 30, 2010
The wire in my house for an elec. garage heater is 14 gauge wire with a 15 amp breaker. I assume i need at least 10 gauge wire with 20 amp .The heater is 20.9 amps and 3000-5000 watts, with 17500 BTUs
Curt, a 20 amp breaker will blow if you pull 10.9 amps from it. I suggest having a licensed electrician do your wiring. Likely, you need a permit anyway.
Oct 22, 2015 | Water Heaters
As soon as I turn headlights on it blows the fuse for gages on dash no wires touching and lights don't come on gages work if I don't turn headlights on
Hi Bobbi
A 50w Headlamp will draw 4 Amps (Ohms Law 50/12=4.1)
So... 2 Low beams will draw 8 Amps.
Obviously more for high beam and high wattage Quartz Bulbs.
That is a lot for a small switch (contacts) to handle.
This is why a lot of vehicles use a Relay to power the Headlamps.
The relay is connected directly from the Battery to the Headlamps.
The large internal contacts can handle the higher current (30A) and the dash headlight switch connects to the magnetic coil inside the relay and is only used to pull the contacts closed.
Does your circuit include a relay.? Do you hear a relay click?
simple headlight relay wiring
To assist with your troubleshooting, try disconnecting one head lamp bulb to reduce current load. Does the fuse blow?
A temporary12v circuit breaker could be substituted for the fuse until you determine the problem.
If the circuit is using a relay then there will be a fat wire going from the battery to the Relay. The fine wire on the relay input is the trigger. A 12v test lamp is really useful for troubleshooting around the car. Also a cheap multimeter. Clamp style current meter is also handy to see exactly what current is blowing the fuse
Relays
http://www.ebay.com.au/itm/NARVA-CIRCUIT-BREAKER-REPLACES-STANDARD-BLADE-FUSE-BATTERY-15A-AMP-12V-55715-/321234642731?hash=item4acb13a72b
There is a 10A circuit breaker also like above
Automotive Circuit Breakers Wiring Products
Sep 13, 2015 | Cars & Trucks
Tail light wiring color code 2005 dodge cgrand caravan
Sounds like you have the wrong part.Did you buy it new or is it used?
Aug 02, 2015 | 2005 Dodge Caravan
2 WIRES PULLED OUT OF THE PLUG ON BACK OF ALTERNATOR ONE WHITE WTH RED STRIPE ONE BLACK WTH WHITE STRIPE WHICH ONE IS IN THE CENTER
dont guess.
ouch, the FSM shows all connector pin outs in the rear.
you never said the year.
nor country diff, countries have different harness colors.??????
my 04' FSM shows.
2 wires. (not counting case and big wire)
the 2 plug. called A11 plug.
a11 pin 2 white red. charge lamp.
a11 pin1 black white,,, IG fuse.
but where are the, page 9a-16 shows that.
harness side,
key up, locking key up
1, 2 , X ( x is blank socket pin) left to right.
1 blk-wh
2 whit red,
or go to alldata dot com and look.
Sep 22, 2013 | Suzuki XL7 Cars & Trucks
By-pass 3 speed fan switch
Why don't you just throw it away and get a good fan? I don't think you can wire it without the switch.
Jul 02, 2013 | Hampton Bay 24002 Ceiling Fan
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
Installing cooper 30A 250V female receptacle.
Correct, assuming red and black are connected to the breakers in the breaker panel, and white is connected to the neutral/ground buss bar in the breaker panel.
Dec 17, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove...
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Sep 12, 2009 | Electrical Supplies
My saturn l300 keeps blowing the #2 cooling fan fuse 30a
wiring may be shorting to a ground somewhere check wiring harness and connectors for a ground fault!!swampratt200!!AAAEE!!!
Jul 21, 2009 | 2002 Saturn Sl
3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Dec 06, 2007 | Frigidaire FEB24S2AB Single Oven
Hammering Logo
216 people viewed this question
Top Siemens Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Siemens Hammering Expert? Answer questions, earn points and help others
