Would you please tell me how to reset xerox workcentre 3210 cartdridge chip? I am trying to recharge it but my printer says "no toner" or "toner low" ... Tks in advance. João (jobarbosa9@yahoo.com.br)
  • 9 Answers
Enter tech mode by : menu # 1934 menu - nothing else
run downl3210.bat (firmare update)-you can find it in a lot of places wait aprox 1 min
enter tech mode - data setup
Posted on Oct 22, 2010
  • 2 more comments
  • Alex Pitoc
    Alex Pitoc Oct 22, 2010
    enter tech mode by : menu # 1934 menu - nothing else
    run downl3210.bat
    enter tech mode - data setup > clear all (all count -password 1934 ,all memory)
    that is it
  • Elmer1999 Jan 12, 2012
    i made that, and the printer follow says "tonner agotado", why? what i need do?
    thanks
    i was made that, and the printer says " tonner exhausted", wath i need to do?
    thank you,
  • Alex Pitoc
    Alex Pitoc Feb 02, 2012
    It works if you have firmware version 95 ,in addition enter tech mode by pressing menu # 1934 menu - data setup > clear all (all count -password 1934 )
    or follow instruction on youtube :http://www.youtube.com/watch?v=MIpykMoPQ...
My scanner xerox 3210 scanner locked and I con't find the unlock switch
It's located where the paper comes out above the toner door. It's on the top side on the left. Put your hand inside where the paper exits on the left side and it's above your hand.
Jun 27, 2016 | Xerox 3210/N WorkCentre series 3210/N MFC...
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
Hi Marco,
They have a chip in them and can't be fooled so to speak by topping them up.
You can get toner and chips off ebay if you do a search for your model...
refer to link for an example...
http://www.ebay.com.au/itm/Hi-Yd-Toner-Refill-Reset-Chip-for-Xerox-WorkCentre-3210-3220-106R01487-/261253227411
Oct 26, 2014 | Xerox WorkCentre 3210 - Multifunction -...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox WorkCentre 3210 invalid toner
Verify you are use OEM Xerox Toner. If so, try reboot the unit, take out and reseat the toner. If that doesn't fix it you'll have a bad main board and will need to be replaced.
Sep 12, 2013 | Xerox WorkCentre 3210 - Multifunction -...
My m20i still says toner low after i replaced it. Is there a reset button I need to press somewhere?
toner or drum?? if toner the chip may be defective or wasnt changed at refill. if its the drum, print the help page to guide you to that section. and reset.
Oct 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
4,184 people viewed this question
jasbo
jasbo
