Question about Garden
I have a bolens tiller mdl #21a-250h065 183626 and belt came off i need a illustration on how to mput back on
2 Suggested Answers
SOURCE: Bolens model 3012H lawn tractor attachment install instructions
I don't know the answer to this question but I wouldn't mind getting one of those tillers for my tractor. If you ever decide to part with it let me know! j e s s e m e r s o n @ m y m a c m a i l dot com
Posted on Aug 12, 2011
I have a bolen snow blower with a 208cc engine that runs for 5 minutes then quits seems to lose compresion
you may want to try and see if your cylinder walls are scratched when it loses compression try using som oil in the cylinder and see if the compression comes back up. if so then you may have a scratch cylinder. if compression does not come up then look at the valves to see if they are seating right. if not then you may have to do a valve job.
Jan 26, 2015 | Bolens 158 cc 24" Front-Tine Tiller CARB...
" How to put belt on Bolens self propeled/ self muliching 21' push mower
should be some sort of tensioner device or spring that would need to be slacked off in order to facilitate removal try that
Jul 24, 2014 | Troy Bilt Tiller Bolens Swivel Post Pn...
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
May 04, 2009 | Garden
Changing the drive belt
pull the bracket
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
