Philips lc320w01 problems - my hdmi cable is in - yet no sound? (do i need an extra wire? where can i find it?)
jsinex2421
  • 62 Answers
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Posted on Jan 10, 2009
demonicsaint
  • 160 Answers
SOURCE: No sound with HDMI cable connected to Philips 42PFP5332/10 TV
Sony Vaio laptops do not allow audio through HDMI only video. You can run audio from your laptop however to a surround sound system.
Posted on May 07, 2010
SOURCE: Vizio 47 in. HDTV LCD Television Problem
how to get rid of captions on T.V.screen
Posted on Jul 26, 2010
  • 79 Answers
SOURCE: my problem is that i
Hello rpgscope,
I am assuming both your dvd recorder and cable is plugged into your tv? Conncet a composite cable (rca cable or aka red, white, and yellow cable) from cable box OUT to dvd recorder IN. That should fix the problem. I mention composite cable but if you another slot for av then go ahead and use that. Make sure you have AV connected from dvd recorder OUT to the tv IN. Also the cable box should be HDMI OUT to tv IN. If you have it connected like this, it should work. Hope this helps.
- Joe
Posted on Aug 30, 2011
gopakumarg43
  • 74377 Answers
SOURCE: need codes for philips lc320w01
Check these codes.
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Posted on May 07, 2012
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
Jan 14, 2014 | Televison & Video
Problems connecting laptop to Philips TV
Is your laptop use fn F6/F7 to toggle between internal/external screen ? Try it
Jan 04, 2014 | Computers & Internet
Hdmi cable no sound
HDMI cable going from my time warner HD box to my new 50" panasonic viera (TH-50PZ800U) no sound, amazing video. the HDMI is a belkin btw if it's even needed to be known.
Aug 17, 2012 | Philips 52PFL5603D/27 52 in. LCD TV
May 07, 2010 | Televison & Video
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Can't get sound through my hdmi
Try the easisest route first - unplug and replug HDMI cable into same port or the other hdmi port on the TV. Also, make sure the Monster cable isn't HDMI 1.3 - I'm not sure the HDMI ports on this tv are fully compat with 1.3.
If that fails, go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software" - read the specs and see if it says anything about audio loss on HDMI - many Philips have issues with the HDMI ports - they are not broken, but just need a software fix. Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Here are the notes I see:
BX23U-1.5.0.0_03531
Following problems are solved :
• Availability cablecard channel map.
• Improved info in the service menu.
• Improved picture quality and stability on HDMI.
• Installation of channels.
BX23U-1.4.0.0_03081
Following problem is solved :
• Issue related to intermittent video loss is solved.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
How to set up high definition xbox with flatTv
If your talking HDMI cables yes you can go Cablemart.com and get HDMI splitter boxes. a slew of additional parts and they are about the cheapest and the best built.
Have two 50" HDMI cable from them.
Jun 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
Televison & Video Logo
447 people viewed this question
Top Televison & Video Experts
Electro Med Services...
