Question about Dryers
What size belt does a maytag PYE2300AWY take
  • 259 Answers
Your dryer uses the whirlpool dryer belt part number 341241 it is 92 1/4” long, and 1/4" wide,
Posted on Sep 13, 2010
Musy clarify problem with maytag dryer. heat is working fine but drum stopped turning is it possibly a belt or something got stuck? i can turn drum by hand
You've almost assuredly got a broken belt. There are so many different ways of disassembling various makes and models of dryers, there is no 'one size fits all' instruction to guide you through it.
Mar 17, 2013 | Maytag Dryers
Just want to know how to get to the belt of my maytag dryer
Instructions
Things You'll Need:
* Tape measure
1. Measure the waist for the person wearing the belt. You need to add 2 to 3 inches to the size when you buy a man's belt. If the waist size is 34, get a 36 or 37 belt. When you buy a man's belt, you want to make sure that the stem of the buckle fits in the middle hole.
2. Choose the appropriate color, matching the shoes and the belt to get a finished look. The shoes should go with the outfit. If you have a black suit, don't buy a brown belt.
3. Make certain the belt isn't more costly than the shoes. You need good quality in both, but if you pay a huge amount for the belt and wear shabby shoes, you still look bad. Get something that's good quality with a comfortable price.
4. Purchase a leather belt if you want to use it with a suit. Leather belts are dressier. Cloth belts tend to be more informal and go well with khakis and shorts.
5. Select a belt buckle that goes with the outfit. When you buy a man's belt for a formal occasion, you don't want a large belt buckle. Simplicity for formal wear and that big turquoise belt buckle for those jeans and cowboy hat is a rule of thumb.
6. Keep the width down to 1 1/2 inches if you buy a man's belt for formal occasions. Anything wider is strictly for casual wear.
Mar 07, 2011 | Maytag Dryers
I have an 11 year old Maytag model PAV2200AWW. My problem is the clothes are still "very wet" after the spin cycle. I've changed load sizes, water levels and checked all of the hoses. Any...
replace washer belt # 21352320 tilt washer back belt on bottom ...check for glossyness on belt and black residue causing belt to slip... make sure motor and pump pulley moves freely...
Jan 27, 2011 | Maytag Washing Machines
Matag dryer PYE2300AWY will not start. When the selector button is engaged the machine will not start
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Nov 21, 2009 | Maytag Dryers
Maytag washing machine is locked up and will not spin.
Sounds Like The Belt If Inclined Remove The Outer Case Front And Replace Belt Of Equal Size From Any Auto Parts Store.
Jan 05, 2009 | Granberg Bar Mount Chain Saw Sharpener,...
Dryer
there iws another pully with a spring to rap the belt around neer the motor.this pully puts pressure on the belt.
Aug 19, 2008 | Maytag Dryers
Open Questions:
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
