Question about GPS
Audi a6 4BO962258C 410.215/006/003 for japan only american model, water entered inside the car under the drivers foot mart is a box that controls the door lock ,he window, the inner lights, and the boot, all of them is not working due to water entering the box, i need the box , the NUMBER above is the box number
rytech uk
  • 85 Answers
SOURCE: serial number
if you mean serial number for the tomtom software then we are not able to publish those here, that would be illegal. If you meant the serial number of your device, thwn im afraid no-one will have that info.
Posted on Jun 21, 2008
SOURCE: tv code for my universal remote -symphonic model number sc309e
155 worked for me.
Posted on Jul 07, 2008
SOURCE: Control Lock light remains on
This solved my problem, but the questions is what created the light to be stuck
Posted on Sep 16, 2008
  • 62 Answers
SOURCE: Audi fault code J386 (2002)
There's a TSB on that problem. It involves broken wires in the A and B pillar from the central convenience module to the rest of the car. Ask your VW dealership or what not for a more specific answer.
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: 1999 Audi A3 1.8T Electric Windows and Central Locking Won't work
will your passenger door open with the key and is it just one side that your windows are not working or both. if its just one side it might be your regulator motor in the door thats not working if its both it might be your central locking pump usually in the boot. however if both of them are working fine it could be that your key needs reprogrammed however i think the 1st 2 are more likely to be the problem.
Posted on Jun 30, 2009
Body control module location
Look under carpet in front of car either driver side or passenger should be inside a black plastic box
Jan 11, 2014 | 2001 Audi A6
Alarm stopped working, running lights say on and now will not start, found water in battery compartment may have leaked into cab.
I know its a bit late only sined up today your central control unit is blown because of water trapped where the battery is i took the rubber drains out my audi because of leaves an dirt ect blocking them.the water enters through the heater and blows the unit it is located on the p/side just behind the glove box and there not cheap in ireland hope it can help you and many other audi drivers
Sep 19, 2012 | 1999 Audi A4
Water from outside entering car near divers right foot from above
Possible windscreen leak? Have the windscreen sealed. Also check under for any missing rubber plugs.
Mar 05, 2011 | 2003 Audi A8
Hot water leaking under the drive's foot mat.what do we do? Also a lot of steam coming unto the front windshield/ screen from inside
The hot water is may be coolant and may be leaking from the heatercore and causing windows to fog, another thing to check is to make sure the heater box drain is clear and also the rear firewall drains, if you open the hood and look to the rear where the battery is thatarea fills with water due to plugged drains at the bottom, theres a drain on each side and one under the battery but the only way to get this water hot would be if the water would enter the heater box which i kinda doubt, this sounds more like coolant. i would have the hoses checked to make sure its not a hose going to heatercore and causing the leak inside, if it is the heatercore then this is an expensive job, i just noticed the year, a 1994, this may be a heatercore leaking. have the system leak tested and the leak location will be clear. hope this helps.
Feb 12, 2011 | 1994 Audi 90
How to check 96 audi a6 ECU codes
96 Audi means its OBD 1 protocol! if you have a obd 1 diagonsis tool you can check the ECU!
Jan 23, 2011 | Audi A6 Cars & Trucks
Audi A6 model 1994-1997 engine 2.8 30V where is the engine control unit placed.
Under the hood there should be a black box above the firewall. This is referred to as the E-box. You may have to remove a plastic cover on the passenger side.
Dec 16, 2010 | Audi A6 Cars & Trucks
Lights, speedometer, windows, trunk and doors unlock all notworkn
multifunction / central locking control unit could cause this problem. located under carpet in left front foot well. [RHD vehicle]. check for water ingress into foot well.
May 13, 2010 | 2004 Audi A4
My Audi a4 driver side passenger foot well is filling with water when stationary, can someone suggest where the water is coming in.
Sounds like the air conditioner condensation drain line has popped off the air box under the dashboard. Good luck, Techjoel
Jun 07, 2009 | 2000 Audi A4
Where is fuse box inside car?
Have you looked behind the glove box or in the diver or passenger side foot wells at the bottom of the A PILLAR where the dash panel meets the carpet.
May 12, 2009 | 1993 Audi 90
Drivers side electric window does not work
2 fuse boxes on cars , one under the hood near battery
And one above your left foot. Some older stupid cars british made hide them else where. Need not be fuse. But finding that out is testing the door itself removing the panel. For you to: Order the Haynes total strip and rebuild repair manual. Of great value.Exists for your model. Will pay back fast...
Apr 09, 2009 | 2003 Audi A4 Cabriolet
GPS Logo
48 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
