Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Model 139.536006 I have a 1988 model and had the same problem as pk5353 after replacing the sprocket assembly/worm drive. It would spin a few seconds and shut off while the limit assembly was no where near the contacts for the upper and lower limits. (I disconnected the chain to remove stress and left the back off so I could watch the limit assembly move back and forth.) My sprocket assembly kit cam with the collar with the two allen screws but I did not install it since my original model did not have it (like pk5353). I replaced the black cap and it appears secure but the motor keeps shutting on and off. Should I try putting the collar on? Any other speculation?
2 Suggested Answers
SOURCE: 25 yr+ old Sears opener runs past lower limit
Update: I remembered that I had a problem with the door reversing too much a while back. It was chattering in the tracks and I could not fix it with lubrication and changing spring tension. So I dialed up the down reversing force. This contributed to the jam-up I had when the lower limit was ignored. If I had a lighter force, it may have at least reversed.
After futzing with it I left it alone for several hours. The motor would hum every few minutes. I was considering cutting power to it overnight. I pressed the remote one more time and the motor ran normally to a limit and stopped. I tested it a few times then reconnected the chain and door. Seems fine now. I suspect an intermitten logic board problem. I'll try lightening up the down force and using it for a while.
Posted on Jan 07, 2009
How do I change the sprocket on my Jonsered 621 chainsaw?
the sprocket is part of the centrifugal clutch assembly
go google and type in ---workshop manual for jonsered chain saws and there are pages of manuals
I opened one page named jonsered 2036 workshop manual --pdf download and it shows how to work on the chainsaw and includes other models in the procedures
that site is www.manualslib.com>brands>jonsered manuals> chainsaws>2036
Sep 26, 2015 | Garden
How to change drive belt
You have not provided the year of your motorcycle so here is the directions for a 2006 Harley-Davidson Touring Bike. If you need advice as to how to change a belt on a different model year post again with the model year and ask again. If you need directions on how to remove the rear/replace any or all of the rear wheel or the swing arm or the primary case or the starter or the front or rear drive sprockets or etc etc post another request and if I see it I will respond to it.
2006 TOURING DRIVE BELT REMOVAL AND INSTALLATION
Remove the rear wheel and the rear swingarm and then the primary chain case assembly and then the old belt from the transmission sprocket and then install the new belt on the transmission sprocket and re-install the primary case assembly, the rear swingarm assembly and the rear wheel.
Jul 14, 2014 | Harley Davidson FLHRCI Road King Classic...
Why wont the replaced liftmaster sprocket turn clockwise after replacement?
Looking down at the sprocket. When it turns clockwise it is closing the door and when it turns counterclockwise it will be opening the door.
Jul 01, 2012 | Sears Craftsman LiftMaster Chamberlain...
The drive gear has shredded and I need a new one. It is a 1991 Chamberlain 1/2 HP Heavy Duty Model 5000. I cannot find the manual to explain what the part is to replace it.
Hi and welcome to FixYa, I am Kelly
The manual can be found here:
http://homeappliance.manualsonline.com/manuals/mfg/chamberlain/5000.html
This is usually the parts that fail:
http://www.wholesalegaragedoorparts.com/Gear_Kits.htm
PN: 41A2817 For the worm gear drive parts
PN: 41A2827 For the Sprocket and Gear Drive assembly that includes the worm drive.
Chamberlan customer support phone: (800) 528-5880
Thanks for choosing FixYa,
Kelly
Mar 23, 2011 | Garden
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
It has a code of PO742. It feels like you are
P0742 Torque Converter Clutch Circuit Stuck On
TSB #00-07-30-007A: Whine Noise in Park or Neutral, Service Engine Soon or Service Vehicle Soon Lamp Illuminates (Replace Drive Sprocket Support Bearing) - (Jan 30, 2002)
Subject: Whine Noise In Park Or Neutral, Service Engine Soon or Service Vehicle Soon Lamp Illuminates (Replace Drive Sprocket Support Bearing)
Models:
1999-2000 Buick LeSabre, Park Avenue/Ultra, Regal, Riviera
1999-2000 Chevrolet Lumina, Monte Carlo, Venture
2000 Chevrolet Impala
1999 Oldsmobile Eighty Eight
1999-2000 Oldsmobile Intrigue, Silhouette
1999-2000 Pontiac Bonneville, Grand Prix, Montana with 3.4L, 3.5L or 3.8L Engine (VINs E, H, K, 1 -- RPOs LA1, LX5, L36, L67)
and Hydra-Matic 4T65-E Transaxle/Transmission (RPOs MN3, MN7, M15)
This bulletin is being revised to add the Chevrolet Impala to the models affected. Please discard Corporate Bulletin Number 00-07-30-007 (Section 07 - Transmission/Transaxle).
Condition
Object
(1) Transmission ID Location
(2) SRTA Tag Location
(3) Hydra-Matic 4T65-E SRTA Tag
(4) Model Year (9 = 1999)
(5) Control Number
(6) Transmission
(7) Serial Number
(8) Julian Date
(9) Calendar Year (9 = 1999)
(10) Model
(11) Hydra-Matic 4T65-E ID Tag
(12) Model Year (9 = 1999)
(13) Line Built (1 = Line 1; 2 = Line 2; 3 = Line 3; 4 = Line 4)
(14) Transmission
(15) Julian Date
(16) Shift Built (A = First Shift; B = Second Shift; C = Third Shift)
(17) Model
(18) Serial Number in Base Code 31
(19) W = Warren Plant
(20) Hydra-Matic 4T65-E
(21) Model
Some owners of the above models equipped with a Hydra-Matic 4T65-E transaxle with a Julian Date prior to 0045 may comment on a whine noise in PARK and/or NEUTRAL or a Service Engine Soon or Service Vehicle Soon lamp that is illuminated. Upon investigation, a DTC P0741 or P0742 may be found.
Cause:
The above condition may be due to drive sprocket support bearing fluting and/or bearing failure.
Correction:
Replace the drive sprocket support bearing. Inspect the channel plate and drive sprocket for any abnormal wear, Turbine shaft for cut seals and/or nicks, and chain for excessive play due to failed bearings.
Important:
When installing the new bearing, the part number MUST be visible (facing upward). Before installing the drive sprocket, lubricate the bearing assembly with J 36850 assembly lubricant.
Refer to the 4T65-E Unit Repair Section for the installation procedure.
Service Part Information:
Part Number: 24214158
Description: Drive Sprocket Support Bearing
Parts are currently available from GMSPO.
Its possible that you can use a voltmeter to test for power and ground at the TCC solenoid connector and also resistance across the solenoid. The scan tool is helpful in pulling the codes, commanding the TCC on and off and monitoring the state of command while driving.
Hope help with this (remem,ber comment and rated this).
Apr 20, 2010 | 2000 Chevrolet Monte Carlo
I just replaced the Gear and sprocket assembly in my craftsman model 139.53635SRT. it opens a few inches but reverses imediately. what can I do?
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Help! chaimberlain/sears 1/2 hp door opener prob.
Fist, turn down the force settings to half. The force settings can damage the door when turned up that high.. Your problem is with the limit settings. This is the three white screws on the bottom with the cover off. You will have to take the bottom off the gear and sprocket assembly and place the limit in the position that the trolley is and adjust the other two screws accordingly.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replace liftmaster 1245R drive/worm gear
I have a 1265 and took the cover off (unplug first).
There are screws securing the cover: 2 on each side at top, 2 at either end bottom.
Then I disconnected the chain.
There are 3 hex head screws securing the drive gear assembly (of course they thread from the inside out which makes taking them out a bit time consuming). Take care not to damage the circuit board or other electronic connections.
Then at the bottom of the shaft is the "limit switch assembly" that is clipped into the metal housing. Squeeze the 2 on the outside and it should swing free.
Then at the very end of the shaft there is another plastic gear. It is secured by a 3 prong plastic clip. Pull the outside clips away from the shaft while pushing the center piece back through the shaft. The gear should come off and you can now remove the gear and sprocket assembly up through the assembly.
call 800 528 2817 and order the "Gear and Sprocket Assembly".
I am waiting for the part and assume we reverse the order above to reinstall.
Oct 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
331 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
