Question about TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System
Mine is a 480 NLS, and it works and boots up in every way, however when you dial 9 for an outgoing line, it used to give a weak studdering type of dial tone, and then it quit giving a dial tone at all. When you call in, you hear the voice prompts and everytyhing, and when you hit 1 for sales, it rings, although you can't hear it ringing on any of the phones in person, then, whether you answer it or not, it goes to voice mail. Allen
2 Suggested Answers
  • 32 Answers
SOURCE: answering machine not working
Open your TalkSwitch Management Software.
Go to Local Extensions/Fax
Select the extension you are using for the fax.
Click on additional settings under the activate extensions section
On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
Posted on Jan 20, 2010
Cannot make outgoing calls
Are you on a phone system? you may have to dial 9 to get local dial tone. If you are on a private line, do you hear tone as you are pushing the buttons as you dial? Or are you trying to call local or long distance?
Apr 21, 2014 | Siemens Lands Phones
Tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
on Feb 14, 2009 | Olympia OL5870 Digital Answering Machine
On a 12 lead generator to achieve 480volts. would i have to tie 4 -7 5-8 6-9. 10 11 12 to neutral. and 1 2 3 are line leads. i can get 240 volts from my center taps, for my regulator. cause line to...
The terminals you listed are correct.
T4 -T7 mated
T5 -T8 mated
T6 -T9 mated
10, 11, 12 combined connection
L1, L2, & L3 = output / line leads
However you should have 277 VAC line to ground and 480 VAC Line to line (Across any 2 phases)
So terminals 1, 2 or 3 to ground should be 277 VAC (L1 L2 or L3)
1-2 or 1-3 = 480 VAC
any combination of
1 , 2, or 3 to each other = 480 VAC
As a "generator man" with 19 solutions one being "You might have to sting it" you should know this and be able to use the diagram on the power head to get your desired voltages unless the wiring data plate is missing. I have had to dial in voltage regulators when switching between 240 and 480 to prevent automatic shut downs from over / under voltage.
Kelly
Sep 18, 2011 | Electrical Supplies
Error prompt: \WINDOWS\system32\c_437.nls
you have a windows system file corruption on the c_437.nls file which is a national languages file required by windows to run.
repair this problem following these instructions-
1. Boot your computer from your Windows installation CD- ie-insert the CD and restart your computer.
2. Select 'R' for the recovery console and log on as administrator.
3. At the command prompt type the following:
cd system32
then press enter
4. Then type the following:
ren c_437.nls c_437.old
then press enter
EXPAND D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
then press enter
(If your CD drive is different than D: or your primary hard
drive/partition is other than C:, substitute the appropriate
drive letters.)
4. Select yes when you're prompted to overwrite the existing file.
5. Reboot the computer.
Depending on the level of file corruption, you may have to repeat this
process for additional files. To do this follow the instructions above substituting the file name.
//javaftper
Aug 01, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
MY WINFAX IS NOT CONNECTING TO SEND. THE LINE WORKS, I HEAR THE TONE DIALER DIALING, THEN THERE IS A LONG PAUSE WHILE "CONNECTING" MESSAGE APPEARS. THEN BRIEFLY THE MESSAGE DISPLAYS "NO CARRIER" AND CLOSES...
This is usually a line connection, or dialing problem. Are you sure the fax modem is connected to a working telephone line? are you sure your sending to a fax machine? Do you require any prefix (like a 9) to make an outgoing call? Are you dialing all the proper digits to make a call?
http://www.getfaxing.com/winfax
Feb 28, 2010 | Symantec WinFax Pro for PC
I need to change the outgoing message on the main line. I can change the personal greeting, but I cannot find instructions regarding changing the main line's outgoing message
For Partner Voice Messaging....
Dial into voicemail. WHen prompted for the mailbox number
Enter 0 #
Pswd the default is 1234 followed by #
Option 3 is the record Automated Attendant menu prompt
the rest is self explanatory.
Nov 19, 2009 | Avaya Lucent Partner 616 Phone
We have a LaserJet M1319fMFP and it appears to recieve faxes ok, but the bulk of our outgoing seems to come back much later on error reprots saying "busy," etc., but when I contact the intended recipients...
It's very likely that if you're using autodial, you've neglected to dial "1" + the phone number, or if it's part of an office that requires dialing "9" first, the speed dial or auto dial doesn't dial the "9" prior to dialing the phone number.
Jul 24, 2009 | Office Equipment & Supplies
C_437.nls file is corrupted and windows cannot start, i also do not have the windows installation disc.
boot in safe mode and run system restore if you cannot boot in safe mode you will have to get a disc and reinstall unless you know how to use the repair panel
Dec 17, 2008 | HP Computers & Internet
Turn on computer- Wont boot Please Help!!!
Borrow an XP install disk from anyone. Since you are not installing a new copy you don't need a keycode or serial number.
I am willing to bet however that you are going to need to do a re-install having lost this file to corruption. The source of the corruption is the unseen elephant in the room. Be aware that if you can get the computer running move any personal files to new new folder on the C drive. One that you create and not in 'My Documents' or any other windows created folder. When re-installing windows any/all windows folders are deleted and new, empty ones are created resulting in your loss of everything.
1. Boot the laptop;
2. press F12 to go to boot menu;
3. Selected CD/DVD-RW Drive;
4. Press any key to boot to CD; worked fine...
5. Press R to repair;
6. At the recovery console, selected 1: C:\WINDOWS and hit enter;
7. This brought me to C:\WINDOWS> prompt;
8. Typed this C:\WINDOWS> EXPAND -R D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
type exit
9. And got the error message: The parameter is not valid. Try /? for help.
IF the disk is in the D drive then use this command instead: expand d:\i386\c_437.nl_ c:\windows\system32\
Oct 19, 2008 | HP Compaq Presario 6310US (DA201A#ABA) PC...
TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System Logo
62 people viewed this question
Top TalkSwitch Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
