Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Remove tv from wall mount
My picture has blown and i want to remove the tv from THE WALL MOUNT. I do not remember attaching the tv to the wall mount with any screws or bolts. It seems that there are 4 knobs on the back of the tv that slid into slots on the wall mount, but when i try to lift tv out of slots it seems to be locked. Is there a latch or something that i need to do to remove this tv from this wall mount?
  • 7 more comments
  • Anonymous May 20, 2008
    remove plasma tv from walll mount
    I need to remove tv for repairs. I had the tv installed on a swivelling wall mount.
    Marla
  • Mellotone Jan 31, 2009
    I am trying not to rip my plasma off the wall. I see 2 little funny screws that keep me from simply taking it off and I have no tools.
  • Anonymous Mar 12, 2014
    No directions in box, confused how to mount to wall
  • Anonymous Mar 23, 2014
    model 6030
    How do I remove back
  • Anonymous Mar 24, 2014
    trying to wall mount tv
  • Anonymous Mar 26, 2014
    I want to wall mount the TV and need to know whether it is flat backed or curved backed
  • Anonymous Mar 30, 2014
    I am unsure which screws on the TV are the ones for the wall mounting bracket
    Genius:
  • 1,224 Answers
There is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
Posted on May 26, 2008
SOURCE:
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
What size screwsare used to attach wall mount
Wall mount for what size TV?
The answer is probably in the instructions that came with the wall mount.
I need: Size of TV.
What kind of wall you want to attach this TV to.
Remember, I am far away and can't see what you are doing.
Aug 19, 2014 | Televison & Video
Hi. I have an old Sony Wega 32" LCD TV which I
ok it depends on the wall mount but this is the basic idea of it. make sure there is at least one other person to help you.
1. Make sure everything is off and unplugged from the tv. 2. If you have cables holding your tv to the wall remove them. 3. there should be securing screws at both sides of the arms attaching the tv to the wall. loosen them/ remove them. 4. lift and pull the tv away from the wall. have a friend help you. 5. remove the screws and bolts from the tv and the wall mount and you should be done.
If this doesn't work, find the manual for the wall mount. if you need help or additional tips put them in the comments. Thanks
May 26, 2011 | Sony Televison & Video
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
14,152 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
