Question about Canon CLC-700 Copier
CLC 700 Hi, I have a Canon CLC 700 copier. Yesterday the machine showed an Error Code of E073. Reason being the paper was jamming on the transfer drum. I then changed all the board on the machine. Now the machine is showing an error code E220 - which is is supposed to mean somehting wrong with the exporsure lense. No wires are damaged, nothing. but the code just will not go away. Can some one please help, as I am loosing money if my machine stands .
  • 47 Answers
Remove the lamp and check the continuity, the lamp may be burnt out, also check the lamp thermal fuse. Failing that, check the continuity of the lamp cable, it may be broken inside the sheathing. And failing that, replace the lamp regulator.
Posted on May 30, 2008
  • Eduardo Celorio Mar 30, 2011
    Might this be a solution? I'm interested on buying these 700 machines.
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Mar 24, 2010 | Canon CLC 1140 Copier
Certain papers, notably a transfer paper that I have used in other machines and have a lot of, will not stick to the drum properly which causes a 'jam' message: "Open front door, remove paper from drum"....
The paper on the CLC-1180 is held to the Transfer Drum by static attraction. Certain papers or media will not work with machine. One thing you can try is to check the flex the paper. Flex the paper and see which way it has the most flex. If the paper has more flex or bend in the Landscape direction load the paper in the Letter "R" direction, or Portrait direction (letter). If the paper is too stiff it will conform to curvature of the transfer drum and Jam.
Canon does not recommend the use of Transfer Material in the CLC series. Canon does have a recommended Heat Transfer Paper for Fabric item # 6094A082AA that will work with the copier.
Canon does recommend aftermarket transfer paper do the damage possible to the fixing rollers. It's possible you could get a Service Tech to adjust the Attraction charge in the copiers service mode to make this paper work better. The CLC 1100 series this very fussy about paper and some papers will just not work. The newer Canon Color copiers use a Transfer Belt which eliminate the bends and provide a straight through paper path much improving the performance with odd or heavy papers.
Mar 01, 2010 | Canon CLC 1180 Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
Cannon clc700 error E073
there is a problem with the transfer drawer
Dec 27, 2008 | Canon CLC-700 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Canon clc-700 stops copying when paper sticks to drum
Could be one of two things.
Either the transfer / separation corona wire is dirty / broken, or the separation current is set wrong.
or
The drum separation claws aren't moving. Possibly a stuck solenoid.
Jan 15, 2008 | Canon CLC-700 Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
Canon CLC-700 Copier Logo
138 people viewed this question
old marine
old marine
