First you can try to light it using a lighter keep the gas knob press and place the lighter near the burner, if it light keep it press for 30 seconds. If it lights ok then for sure you have gas out and you need to clean the spark which probably cover with oil. If this does not help then you need to remove the top cover and check the wires coming from the igniter which is brown or white plastic box with wires in and out sometimes they become loose from exceed heat.
If all wires are ok then you need a new igniter is not an expensive part.
