Question about Sharp Viewcam VL-A111U Camcorder
How to transfer videos from my Sharp viewcam to my pc?
Is there a special cable or what? I don't know what to do! Help!
  • 2 more comments
  • umaroy Jul 09, 2008
    i am unable to transfer my vedios from canon 8mm model es300v to the hard disc can any body guide me
    what are the ways to transfer vedios from a analog camcorder to the hard disc of a pc. i have tried in somany ways but could not suceed can any body help me
  • Dung Nguyen May 11, 2010
    What is the model for the camera ?? Sharp what ? What are you trying to connect your camera to ?
    Chances are, yes you will need a special wire to connect to your ....
  • Ray Cole Sep 09, 2013
    I have used the Roxio VHS to DVD unit
4 Suggested Answers
SOURCE: Drivers for Sharp Viewcam VL-Z3E
USB driver for Sharp VL-Z800
Posted on Oct 07, 2008
  • 205 Answers
SOURCE: Can't transfer video from cam to pc
You can't capture the video with a USB cable. The USB cable and software that came with the camcorder are only used to transfer still images.
To transfer video you'll need a DV cable (also known as a Firewire cable) and some additional software. I use Scenalyzer Live. It's not free, but you can download a demo copy to see if you like it before you buy it. Here's a link to the Scenalyzer website:
http://scenalyzer.com/
If you have the JVC manual you should read page 41. If you don't have the manual you can download it here:
http://www.devicemanuals.com/guide/Digital%20Camcorder/JVC/JVC-Compact-VHS-w-LCD-Screen-Camcorder-GR-D370AS-User's-TWpJME56VT.html
The download link is about half way down the left side. It's a little difficult to find, but it's there.
Lastly, all this assumes that your computer has a Firewirre port. Most new computers will have one, but if you do not you'll need to buy and install a Firewire PCI card. Let us know if you need more help.
Posted on Dec 04, 2007
please send to me driver for Mini dv sharp viewcam VL-Z1
Posted on Oct 16, 2008
SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Posted on Nov 19, 2008
I have an old sharp Viewcam 8mm analog camcorder. It's one of the first models. I bought it in Japan in 1994. How can I transfer/convert my analog 8mm tapes to my computer? My Toshiba Satellite L100 does...
SIMPLE BUY A EASYCAP JUST TYPE IN ON GOOGLE SEARCH EASYCAP AND THEY WILL TAKE YOU TO A PAGE TO OFFER YOU PC FROM CAMCORDER CONFIGUREATION ONLY FROM A TENNER
May 10, 2010 | Sharp Viewcam VL-AH151U Camcorder
I want to transfer my videos taken on my Sharp
You will need a firewire cable and a firewire port on your computer. If you don't have such a port then you can buy a firewire pci card.
See this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Feb 07, 2010 | Sharp Viewcam VL-Z1H Mini DV Digital...
I want to connect my viewcam VL-Z3 to my latop, but I dont have a driver to support it. Can you help?
I had this problem too.
I searched the web high and low. Even wasted 2.99 on what claimed was the driver but turned out to only be instalation directions.
From what I understand, Sharp no longer supports camcorders, so obtaining the dirver from them is out of the question.
Connecting your camcorder to your computer via USB is only used to transfer photos from your SD on your camcorder. You cannot transfer video via this method.
Here`s what I did to solve the problem of not having the driver.
I got a $10 SD card reader for my computer and this solved the problem.
To transfer video from your VL-Z3U to your computer, all you need is a firewire cable .
Assuming that you have a firewire port on your computer, simply connect your camcorder to your computer via firewire, power up your camcorder and your computer should automaticly recognize your device.
You can now transfer video to your computer using your normal video capture/editing software.
Hope this helps
Aug 07, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Viewcam Z VL-Z100
You may need what's called a 'firewire' port, which was the transfer port of choice for most DV models of the time.
My contact at the local RadioShack advised me that a DV-to-USB cable might work to allow transfers since firewire isn't really supported these days. I've not tested it myself though. The cable should cost less than $20.00... and if you're careful with the packaging, you could always return it if it proves useless.
HOWEVER, this is what you may need to allow correct transfer from the cam to the laptop:
http://www.amazon.com/Sabrent-SBT-PCA4-Firewire-CardBus-Adapter/dp/B0007UY662/ref=sr_1_7?ie=UTF8&s=electronics&qid=1252477568&sr=8-7
Check, first, to make sure that the pc-end of the cable is, in fact, a firewire connector.
Jul 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Want to transfer videos from a mini DV cassette to computer.
YOU NEED THE SHARP CD-ROM TO LOAD THE VIDEO DRIVERS ON YOUR COMPUTER TO RECOGNIZE THE CAMERA...PART # IS CDSKAA028WJ01
Dec 24, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Apr 19, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
VL-Z7E
YOU NEED TO PURCHASE A DEVISE CALLED CAPTURE CARD AND CAPTURE CABLE ONCE INSTALLED IN YOUR COMPUTER YOU NEED PROGRAMME LIKE PINNACLE STUDIO TO CAPTURE EDIT AND MAKE CD FOR MAKING DVD YOU NEED NERO 7 OR ABOVE
Jan 02, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
Retail outlets in Canberra
the firewire cable is available at the computer shop when you buy a ee1394 card...the av cable i know is included on the camera kit when you the camera.. if not included then try to the authorized dealer of sharp..
Aug 12, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-A111U Camcorder Logo
661 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
