Question about Panasonic GigaRange KX-TG2420 Cordless Phone (KXTG2420W)
Como puedo cambiar el telefono kx-tg2420 de pulso a tono?
4 Suggested Answers
SOURCE: Panasonic KX-T7730X
Please how do I make conference call?
Posted on Aug 25, 2008
SOURCE: kx-tg2420 handset does not display anything...
please shematic 2420
Posted on Nov 02, 2010
bbl242003
  • 1637 Answers
SOURCE: manual telefono panasonic kx-tg2258 en
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 18, 2011
Manual xg2801
EL SEGUNDO AURICULAR NO ME DA TONO DE LINEA ME MANDA UN MENSAJE EN PANTALLA DE "BORRAR" COMO ACTIVO EL SEGUNDO TELEFONO ....URGE
Jan 22, 2014 | Xact Communication EXG2801 Cordless Phone
COMO DESBLOQUEAR TELEFONO PANASONIC
Hola!, si miras en el telefono, si te fijas hay un boton redondo como debajo de la pantalla y lo presionas por aproximadamente 2 segundos se desbloqueara. Buena Suerte!
Jan 13, 2014 | Panasonic Lands Phones
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Mar 14, 2011 | Logitech X-530 Computer Speakers
Como puedo cambiar el modo fuera de linea? cuando intento cambiar el modo fuera de linea, el telefono me pide que inserte la tarjeta sim, pero ya la tengo puesta y no la reconoce... e formateado el movil...
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockspot.com/nokia-n70/rs10wp9/
Dec 27, 2010 | Nokia N70 Cellular Phone
Como puedo cambiarle la carcaza ami motorokr z6 yo misma? es q se le rompieron unas partes xq se m callo al piso, y ay q compre una carcaza nueva me gustaria saber si m pueden explicar como la puedo...
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
Jun 12, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
Motorola W375
Vas a presionar el boton de menu (es el boton de en medio de el circulo)> Settings > Initial Setup
> Language
Sigue el order que te mostre arriba y luego eliges spanish
Oct 14, 2008 | Motorola Mobility W375 Cellular Phone
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Apr 06, 2008 | Sony Ericsson K750i Cellular Phone
Panasonic GigaRange KX-TG2420 Cordless Phone (KXTG2420W) Logo
57 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
