Question about Samsung X15 Notebook
My dvd/cd drive has dissapeared, windows can't find it I can't find it manually
  • 3,940 Answers
Provided the drive is seen in the system BIOS, just missing in the OS, this should resolve:
http://support.microsoft.com/kb/314060/en-us
If the drive is not seen in the BIOS, and it is removable, remove and reseat the drive. If still not seen, try another drive, if still not seen in BIOS, a Motherboard is a likely replacement.
Posted on May 15, 2008
What's your problem? CD/DVD burn in windows 7
just take to a shop and get the dvd drive replaced its only a 5 min job and the part costs about $30 its only a matter of taking battery out removing 1 screw and the new 1 just clips in
Nov 28, 2011 | Computers & Internet
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
The cd drive in mycomputer dissapear i have a thosiba computer i have put a cd in thecd drive and when i went to my computer an go to cd drive it wasnt there i don know if i removit by accident or what...
Open up the registry by typing REGEDIT in run box. and go to the follwing location.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
on the RHS you will see lower and upper filters simply go ahead and delete both the filters.
Open up the device manager (type DEVMGMT.MSC in run box) and uninstall the CD/DVD drive and restart the PC.
Once again go to Device manager give a Right click on the CD/DVD drive and update it.
Than check ............Your CD/DVD drive will be there in My computer.
Aug 02, 2010 | Toshiba Computers & Internet
I've format my motherboard with windows7 but unfortunately while it was formatting it reboot and the screen dissapear and just come out a blank screen
A little clarification - I assume you actually mean you were installing Windows 7 on your computer?
If you have a valid Windows 7 CD/DVD, put it in the drive of the computer, restart and enter the BIOS setup screen (you will see instructions on the screen as the computer boots up, might say press "esc" or "delete" key to enter BIOS or something similiar.)
MAKE SURE that the PC can boot from the DVD drive; this is normally an option in the BIOS marked "boot order"; make sure the CD/DVD drive is at the top.
Restart and the installation should start again.
Mar 30, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
Acer 5520g laptop dvd drive not regonized
If its not in BIOS then sounds like a hardware problem. usually only 2 cables connects to the cdrom, power & ide OR sata. usually these two wouldnt be disconnected so i suspect bad drive.
Oct 05, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My dvd drive wont read anything it's also saying it's a cd drive everytime i put a dvd in the drive the drive letter dissapear all together
u might need the correct driver for the dvd rom give me the brand and model number ill be more than happy to get u the driver ok...ttys
dragonslair2@hotmail.com
Jul 19, 2009 | Computers & Internet
Gud morning, I my dvd desappered. I cant load any cd. the iocon is not showning. how do i rectify this. I am using HP Pavillion dv6700. my dvd device is "pioneer dvd rw dvr-k17b ata device". Please i need...
ok first of all has anything vhanged, there is a known problem when upgrading XP to vista, where te cdrom.sys rivers arent installed. this is fixable but tedious, if it just simply dissapeared without change, go to device manager:
XP: START> RIGHT click my computer > click "properties" > "Hardware" tab > click the "device manager" button.
VISTA: START> RIGHT click my computer > click "properties" > on the left click "device manager"
under DVD/CD-ROM drvices, you should see your dvd drive, now the field is probably expanded already and it most probably has a yellow exclamation mark next to the device, or it has a large yellow question mark. this means the driver for the vd rive has either failed or is not working properly.
quick fix for this is to simply RIGHT click on the device, click uninstall, confirm, and once un-installed, re-start the machine. apon restart windows should automatically detect the dvd drive as a new device and install it.
if there is simply no device listed under DVD/CD-ROM devices, or the catergory isnt there, windows isnt detecting it at all, which commonly means the dvd drive itself has failed, (the fact it may be powered and opens/closes is irrelevant). but before throwing it away, try changing the IDE/SATA cable. if the uninstall/re-install doesnt work, you may need to re-install it from a winows disk, which is a little tricky. but can be done. let me know if it doesnt work and i will pace you through it.
David
Jan 02, 2009 | Pioneer DVR-107D DVD±RW Burner
Cd/dvd drive doesn't show up anywhere
Have you checked device manager to see if the drive is in there and has exclamation on it??
Nov 16, 2008 | Dell Inspiron B130 Notebook
Windows x.p. home edition does not read my camera, also does not automaticaly read d.v.d if inserted into d.v.d. drive. Both used to work but have dissapeared, any ideas?
usually windows will recognize it as plug and play but there should have been a cd that came with the camera and for the dvd you will have to reinstall the drives from the cd that should have came with the dvd player
May 02, 2008 | Computers & Internet
Samsung X15 Notebook Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
