Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How do I change the number of incoming rings to 2?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Dec 14, 2012
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
Change number of rings on incoming call before it goes to VMS
Changing the vms hunt delay on a Partner ACS system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#505"
the display should say vms hunt delayand mode:
enter 1 for day mode or 2 for night mode
enter line you want to program in 2 digit format (line 1 =01)
enter number of rings (2)
press feature "00" to logout
hope that helps
Jan 05, 2009 | Comdial Avaya Partner ACS Phone
How can I change the Rings to Answer setting to one ring?
1.
Press Setup.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Jun 28, 2007 | NTL VS1500 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
16 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
