Question about Intermec EasyCoder 4420 Thermal Label Printer
I cannot seem to cancel an old job stuck in there. I have hit cancel, powered off and on, unplugged. Everytime I try to print a new job it puts out this old one.
  • 29 Answers
I cannot seem to cancel an old job stuck in there. - moz-screenshot.pngThe best thing to do is do a memory reset. But this could also clear pages and formats, user defined characters and fonts, configurations,tables,or all of these parameters.
To reset memory
1.Turn off the printer.
2. Set the DIP switches to reset a portion.
3. Press and hold the Feed/Pause button while turning on the printer. The printer prints out a hardware configuration test label.
4. Hold the Feed/Pause button for 1 second. The printer resets a portion or all of its memory.
5. To exit test and Service mode, turn off the printer.
6. Reset the DIP switches to their original setting and then turn on the printer.
That should do the trick.
Posted on Sep 13, 2010
  • lisa_parker Sep 13, 2010
    I don't know what a DIP switch is....
  • pedro jr rayos
    pedro jr rayos Sep 13, 2010
    The DIP switch I am referring to are the switches at the back. On the Top Bank switches turn the number 4,5 and 6 switches to ON. and perform tasks 3 to 6.
    Let me know what happens
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
My dell dimension 2400 series computer has lost comms with the local dell AIO A920 printer. Connections seem to be good. It seems a print job has got stuck somewhere. HELP! AJCook
how your printer icon is looking on control panel, if dim, it means it is not detecting , if normal it means detecting then,
go to control panel open printers, then open your printer, cancel all the documents, then send a print command and check
Nov 01, 2008 | Computers & Internet
Us.mg1.mail.yahoo.com is stuck in my printer que and I cannot cancel or delet it nor can I print anything else
Unplug your printer and leave it unplugged for at least a minute. Also reboot your computer. It will clear the printer queue!
May 05, 2011 | Yahoo Mail
Print job will not print nor delet. what do I do
Make sure to clear any print jobs stuck in the queue first before trying to print again. If you're using Windows, follow the steps below.
If you're using Mac, launch Terminal and simply type cancel -a -
Before trying to print again, make sure the printer driver is properly installed. You can download the latest Lexmark X5470 driver from the Lexmark website for free. Make your Lexmark printer your default printer.
You can also try to unplug and replug the printer to the power source to reset it. This seems to fix minor communication issues.
If problem continues, please contact Lexmark technical support. Thanks.
Dec 13, 2010 | Lexmark X5470 All-In-One InkJet Printer
My job will not print and I cannot cancel it or clear it. I have tried unplugging the power, turning the printer off and on, sending new jobs...nothing works.
For Windows try a combination approach. Unplug the data cable from both the computer and the printer (USB). Then stop the print spooler and restart it. You could do this from the Control Panel (System Services). I find it easier to do this from the Command Prompt (For Vista and Win7 you need to run as administrator) Start > All Programs > Accessories > right click on Command Prompt and select Run as Administrator (for older versions just left click on the Command Prompt).
At the prompt in the window, type "net stop spooler" without the quotes followed by hitting enter.
At the next prompt, type "net start spooler" again without the quotes and then hit enter.
(Press y if you are prompted with a warning about fax service after the first command). Then restart the computer after you see another prompt.
Once your computer has rebooted, check if the spooler is empty before reconnecting the data cable. Then try to print another job.
I hope this helps.
(you can actually stop the service without restarting it and then reboot. However, you need to take a long coffee break before the spooler finishes clearing the stuck document.)
Nov 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
Printer is ''stuck'' on a bad job
Go to computer, control panel, printers, Under you Image runner right click and cancel all print jobs.
Nov 14, 2009 | Canon imageRUNNER 5000 Copier
I am trying to delete all other jobs and jusr print a new job and my printer is just continuing printing out all the old jobs. I have deleted them from the list but it is still printing them. Any ideas??
I had the same problem once. Try this... with the printer on ... unplug it. This might empty out the buffer on the printer. If it doesn't, do this...let it start to print and then hit cancel. Let it spit out the paper and then reload that piece of paper back onto the tray. Do this till all the old jobs have been completed. At least you didn't waste a lot of paper and ink.
Thanks,
RSMITH972278
Oct 14, 2009 | Epson STYLUS CX5900 Printer
Hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Jun 22, 2009 | HP PSC 1350v All-In-One InkJet Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Intermec EasyCoder 4420 Thermal Label Printer Logo
681 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
