Question about Whirlpool Dryers
Whirlpool dryer model LER4634EQ2 Type 122-00 Lost power. Does this dryer have a fuse and where is it?
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Posted on Mar 07, 2009
  • 221 Answers
SOURCE: cloths not drying
Hey jeff, you can test a heating element for continuity with an ohm meter, good luck.
Posted on Mar 23, 2009
  • 23 Answers
SOURCE: dryer stopped working... wont turn on
Before starting troubleshooting-Unplug the dryer, because you will be removing front panel for this check.
There are several things that can cause your problem:
#1 of which is a clogged up lint trap and/or vent duct raising the heat that could cause your thermal fuse to open (blow). What to do: Make sure that duct and vent outside of wall are clear, if they were obstructed, then the thermal fuse can be checked for continuity with an ohm meter, it is located in the fan housing with 2 terminals coming off of it, if it does not have continuity (connection) between terminals, you will need to replace it, simple and less than $15 bucks.
NOTE: this problem can also be caused by a bad thermostat letting dryer get to hot which in turn blows the thermal fuse., sooo after changing thermal fuse you need to check that the temperature of air leaving dryer duct does not exceed 150 degrees, if it does replace the thermostat for less than $25 bucks, this maybe be what caused your problem in the first place. Good Luck!
Posted on Apr 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: dryer will not start whirlpool
It might be the fuse.3727d80.jpg Be sure you do a bit of cleaning before you replace the fuse or it might just blow again.a611954.jpgca0922b.jpg Look for lint. I looked up your model. I once did a write up about what goes wrong, how to get into the machine, a training manual and videos. HERE
Bonus stuff
Helpful? Rate please.
Posted on Sep 19, 2010
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool dryer model ler4634eq2 runs,
Hello
No heat in your whirlpool is caused when the thermal fuse goes bad and needs replacement. As everything else is working so the problem is with the fuse which is located on the blower wheel housing inside the back panel and to replace you'll have to open it. Please get back to me if you have any other questions.
Kevin
Posted on Nov 11, 2010
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it.
Hope this will help you
Feb 27, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer model ler4634eq2 runs, but will not heat
Hello
Kevin
Nov 11, 2010 | Whirlpool Dryers
Dryer will not start whirlpool model #LER4634EQ2 SERIAL #MK0296464 TYPE#D433-ELE-2406028-FM54
Bonus stuff
Sep 19, 2010 | Whirlpool Dryers
Dryer was running. Put in a new load and it won't turn on now. I checked the fuse box, it was good. any idea. model # LER4634EQ2
Thermal fuse. Pull rear panel off and theres a little white fuse with two blue wires on it. Its got one quarter inch screw. You can tie the two wires together and check if that is your problem - but I recommend replacing the fuse. Good luck...
Nov 16, 2009 | Whirlpool LER4634J Electric Dryer
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
No start, not even a noise to speak of.
Thermal fuse located on vent after element package. it should be a white rod about an inch long and has 2 wires connected to it. Hook those 2 wires togther (that will bipass it) if that works, thats what it was. Make sure to replace it soon after, it is for safety purposes to prevent over heating.
Aug 26, 2009 | Whirlpool LER4634J Electric Dryer
Cloths not drying
Mar 23, 2009 | Dryers
Mar 07, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
129 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
