Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Silly Dishwasher Hello, I have a huge problem with my less-that-12-hour-old Bosch SGS56E18GB. We are not generally thick people. We plumbed our dishwasher in, like we have plumbed in many appliances. Switched on the dishwasher for the first time and GREAT!!! Here we go! I can tell this is not going to be plain sailing. The dishwasher has already decided that it wishes to do the short cycle. (19/29mins or something) I Press on then off - no change. Reset, Off - on, still no change. So I decided to let it run the program just encase it was a factory setting for the first use. I waited and waited and WAITED!!!! The flaming thing will NOT end the cycle. Its stuck on 1 minute left.....for 15 silly minutes. No good, try again. Run the cycle and it did the same thing. So I reset the dishwasher as I managed to do it this time. Led turns to 0, but you can clearly hear the pump still chugging inside. This clearly is not right. Can any one shed light on what we can do now. Much appreciated, kel
Press and hold scrub and delicate at the same time for 3 seconds then let it cycle turn off it should reset.
Posted on Jun 08, 2008
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
My Bosch Dishwasher 6800 is not rinsing...after HOURS of running, sometimes the bottom of the washer is filled with suds. I use very little detergent and still have trouble.
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch dishwasher, however if you could post the complete model number (6800 is incomplete) I can speak directly about possible remedies instead of generalizing.
The one possible problem could be your door switch in the latch assy, hence it present's an error code.
Thank you for choosing FixYa. I'll need to watch for your reply before moving forward.
Regards,
Macmarkus :)
May 03, 2011 | Bosch Dishwashers
Dishwasher not emptying
Hi, I have a coulpe of question's to start off, how much water is left at the end of the cycle we're talking about and how long does a typical cycle last ? 2-3 hours or 2 hours & less. Has there been any changes recently with plumbing or hot water tank etc ?These are just a couple of factors which will go a long way to finding you a solution. I look forward to reading your reply. Macmarkus :)
Apr 12, 2010 | Bosch SHV68 Built-in Dishwasher
New Bosch dishwasher mold before cycle
The Bosch is a very good dishwasher and it is very airtight. I would suggest you NOT leave the dishes inside that long, and always use the Power Scrub Plus cycle if you have it. It will get the water as hot as possible so mold does not continue to grow in the plumbing and filters.
It is NOT the dishwasher unit causing the problem.
Jul 14, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel Type S9N61B
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Jul 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3036UC not filling with water
u need more info first what happens when u shut the door and start a cycle
Nov 05, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
216 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
