Hello ! i can not add a computer to my router. i see it in network manager map but its say on the other computer local connection only . so this computer can not access internet i use windows vista. thank-you
  • 2 more comments
  • racmichel Sep 13, 2010
    Hi
    Again i know the key for the router WPA2 security.
    I see it on the other computer when i do the connection but it's says acces local only
    and network not identify on the other pc.
    Thanks
    Hi
    pc i try to connect IpV4 = 169.254.145.198
    mypc = 192.168.1.101
    thanks
    hi
    i did that already but i tried again it's still the same ip adress
    Thanks
    hi again
    my router see the new pc but i still can not acces internet it's saids its a local attachemnet only
    thanks
  • 6,487 Answers
Base from the description of your problem , the problem here can be with the wireless settings that you need to connect to that wireless network of your router.
If your router has a wireless security enable on it like WEP or WPA make sure that you have the correct security key because if you don't have that your computer wont work.
Posted on Sep 13, 2010
  • 2 more comments
  • Mark Gil
    Mark Gil Sep 13, 2010
    OK thank you for the information, since you're sure about the WPA key lets check if that computer is getting a valid IP address. To do that go to that non working computer then open command prompt, To do that click Start > Programs > Accessories > Command prompt once its open type there IPCONFIG and hit enter look for IP V4 then please to provide it to me.
  • Mark Gil
    Ok that;s the the reason why that computer is not getting online because its not getting a valid IP address, did you already restart that computer? if not please to restart it and check again the IP address.
  • Mark Gil
    if that;s the case we need to set static ip on that computer to make it work. Follow these steps on how to do that.
    From the Start Menu, go to Control Panel > Network and Internet>Network and Sharing Center.
    From the Tasks list on the left, choose Manage network connections.
    Result: A screen appears with LAN or High Speed Internet.
    Right click on Local Area Connection.
    From the drop down list, go to Properties.
    Result: The Local Area Connection Properties screen appears.
    Highlight Internet Protocol Version 4 (TCP/IPv4) and click on Properties.
    Result: The Internet Protocol Version 4 (TCP/IPv4) Properties screen appears.
    Click on Use the following IP address.
    This will be the value that you need there , then click OK all the way after putting those number in
    IP 192.168.1.15
    subnet 255.255.255.0
    gateway 192.168.1.1
    dns 4.2.2.2 and 4.2.2.3
  • Mark Gil
    Did you already setup those number to that computer ? tell me the IP address of that computer now.
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
Tip
How to Map the Storage Drive Connected to F5D8235/8635 N+ Wireless Router?
Important Note: Pleasemake Sure that you are able to Ping the Router's IP address, on the computer onwhich you want to map the Drive.
Installing Storage Manager Utility toMap the Storage Drive:
Run the Installation Disk on the entire computer connectedto the Network, which will install Storage manager utility.
This Storage manager utility will automatically map thedrive (e.g.: Z drive) and which can be found in My Computer. Double click onthe drive created in My Computer (e.g.: Z drive) to access the data, which isstored in your Hard Drive, connected to the router.
Mapping the Drive Manually:
If you do not want to Install Storage Manager then you cango for Manual Mapping.
To get the Drivemapped and listed in the My Computer then follow the steps given below.
· Click Start and Right Click My Computer
· Select 'Map Network Drive'
vargheseacer_4.jpg·
By Default, Select Z: in Drive box.
· In Folder box, type in ' (IP address of therouter)(Drive name)
For e.g. 92.168.2.1DriveName
Note: Connect the StorageDrive directly to the Computer to modify or check the name of the Drive
· Click Finish
Double Click on the drive to access the data, which isstored in your Hard Drive, connected to the router.
Or
You can Access theDrive Files Directly without Mapping the Drive:
Click Start and Go to 'Run', Type in " (followed by IPAddress of the router)".
E.g.
\\192.168.2.1
This will take you to the Window where you can find the nameof your drive. Double Click on it to access the data, which is stored in yourHard Drive, connected to the router.
Note: The Router Does notassign IP Address to the Storage Device
on Dec 12, 2010 | Belkin F5D8236-4 Router
No wired network connection
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps
Nov 27, 2011 | HEWLETT-PACKARD Pavilion p6674y...
How do i get a netgearn300 router to get a connection from a wifi device
Well connecting to your router is simply a matter of joining your wireless network. When you try and connect to the PS3 the router will automatically route your traffic to the PS3. The real question is does a PS3 support SMB or CIFS (file sharing protocols) that windows will understand. If it does just enable them on the PS3. Then in Windows open up "Computer" and click "Map a Network Drive", select a drive letter to map to on your local computer and for an address it will be in the form \\<PS3 hostname>\<share name>
Nov 13, 2011 | NetGear N300 Wireless Router
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    I have wrt160n router, when i tried to add my laptop(xp) it doesnt allow. msg says, "router has been set up but can not detect internet connection" pls help.
    Likely you need to run the connection wizard in order to regain your connection. Also when using more than one PC with a router, some ISP's only allow one pc to be connected per account. To fix this problem, use the clone mac address feature in the router to clone the mac of the original PC that was connected, the router will then behave as that PC and split the connection by routing to any other pc connected using a single mac address. When you add a second PC because the provider only allows one pc per account - it then loses connection. The router fools the ISP by cloning the original mac.
    Aug 29, 2009 | Linksys WRT160N Wireless Router
    Second computer cant connet through the router..
    You must reconfigure the wireless settings on the wireless computer. Go to Network and Sharing Center > Manage Wireless Networks. Now you must delete all the prefered wireless network profile there. If they are all deleted, click on ADD > Click Add A Network in range of this computer > Select the signal from your router and connect. If it asks you for a network key, you should know that, otherwise, contact your router provider to determine what your network key is. That should solve it.
    May 06, 2009 | Computers & Internet
    Linksys Wireless-N pci adapter model wmp300n
    If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
    May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
    I can not get access to internet
    what is the operating sys on your computer
    if vista
    and if you know what is the wireless encryption key
    then
    right click on the network icon ( on the bottom right hand side)
    chose network and sharing center
    then on the right hand side select manage wireless networks
    click on add a network
    choose to add a network that is in the range
    from the list of the networks found click on your network
    when prompted enter the n/w key and once connected click on finish. hope that helps
    May 02, 2008 | Linksys Wireless-G WRT54G Router
    Netgear WG602 wireless router, Connection Local only !
    What I think is you unplgged them at the wrong times.
    Do this:
    (in this order)
    1. Turn off the router.
    2. Turn off the modem.
    3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
    4. Now turn the modem on.
    5. Wait for the lights, then wait about another minute for it to settle.
    6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
    7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
    Now tell me the errors, like if it says connection limited,etc...
    Thanks,
    Cam
    Oct 18, 2007 | NetGear WG602 802.11g/b Wireless Access...
    Computers & Internet Logo
    15 people viewed this question
    David Payne
    David Payne
