Question about Philips Magnavox 27MS343S 27" TV
Wont say On
I have 19 Magnavox PS1944c127 It will not stay on. Hit on button and powers up for about 2 seconds then shuts it self off. Same using the remote and with remote out of the room
  • 66 Answers
This TV needs to be taken to a service center, its problem is internal and needs a qualified technician service center to make the simple repair.
Posted on May 15, 2008
My asus vw193D-B shuts down
Check cable. It's not communicating with PC video card. It should pick up the input port, but make sure on monitor. You can try re-seating video card. Also test with VGA if you are using HD like HDMI.
Aug 29, 2012 | ASUS MNTR ASUS| LCD 19' 5MS VW193D RT...
MY TV WONT STAY ON. WE TURN IT ON IT TURNS OFF. WE DID THE RESET SYSTEM BUTTON.
when it shuts off and power light goes off do the self check this model has.
When green light (power) goes out, on front of set press and hold both the menu and Input buttons for at least 5 seconds and release both.
WATCH THE POWER LIGHT closely, the light should blink a two digit error code.
for example, 2 blinks, 2 blinks and a pause, it should repeat the code at least five times.
Let me know what code you detect and I will tell you what it means.
SD TECH
Feb 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
My laptop shut down and wont start up anymore.it tries to start up. i brought a new battery,but that doesn't seem to be the problem.it still wont start up.the blue light button that you use to start it...
The new battery stays on the shelves for quite some time and probably discharged. Does you ac adaptor work? Make sure it does, charge it up first a bit then start it. If you have voltmeter, you can measure its output which should be around 19 volts. Sometimes the connection to the laptop also gets loose after a while, but make sure the ac adapter has power to it.
Aug 12, 2009 | Computers & Internet
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Demo mode
Try pressing the vol up and vol down buttons on the tv at the same time(not on the remote)
Sep 09, 2006 | Philips Magnavox MT1905B 19" TV
Philips Magnavox 27MS343S 27" TV Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
