Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung Syncmaster 214T flickering
I read on one of your posts that your fixed your Syncmaster 214T. I have the same problem and I still can't find the solution. Can you please explain what the solution is and what part/parts did you change?
Thanks a lot
My email is kbelhocine@yahoo.fr
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. We just posted a repair guide showing how to remove the case ans replace the parts. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
Our samsung 214t will not display a decent image until it has been turned on and off a few times. Any thoughts?
You have a power supply in the monitor that is failing. This is a known issue with these great monitors. It is a simple 20 minute repair. We have a step by step repair guide for ts model posted on our site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ The repair involves replacing 5 small parts called capacitors. If you don't want to do the repair yourself we do offer a repair service for this model, the repair service runs $32 plus shipping.
I hope this helps if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
The display on my Samsung Syncmaster 214T is very dark and only the very light parts of the desktop ca be made out. It happened yesterday also and then switching the power off and back on solved the...
Your monitor has a failure in the back light power supply, this is a common problem in this model after a few years of use. The repair is easy and only takes about 20 minutes but it does require soldering to replace 5 small parts called capacitor in the power supply. We have the step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service, this runs $32 plus return shipping. You can get more information on this service at: http://www.ccl-la.com/blog/index.php/service-request-form/
We hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 23, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214T wakes up from hybernation flickering (Windows 7)
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 19, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Apr 22, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
584 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
