Question about Lexmark X4270 All-In-One InkJet Printer
Printing I need to know how to set the printer to copy the long 8.5 X 14 sheets of paper. It isn't hooked to a computer. My e-mail is lparrish64@yahoo.com I have worked with it and I can't get it to print the whole page. Please Help.
    Guru:
  • 1,463 Answers
Hi shortie pant
if you want fresh drivers they can be got from here Drivers and Downloads select your o/s and also you country from the top of page as well.
also check out the support section at top of the page if needed .
riz.
Posted on May 15, 2008
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
Letteres printed on a Monochrome printer offset type onto themselves
Which print finishing setting do you use: Draft, Normal or Best?
Mar 07, 2008 | HP LaserJet 1320 Printer
To fax do you send paper through it or scan it to an e-mail
Assuming you have it hooked up to a phone line that is capable of dialing the number you want to fax to, you put your paper in the top tray, dial the number and hit send. The machine will pull through the paper and deposit it under that top tray. You will want to make a copy first so you know you are putting in the paper facing the right direction (it should be face up.) Put a single sheet face up in the top tray and hit copy. If what comes out of the bottom-most tray underneath is an exact copy of your original, then you're fine, if it's blank, then flip the orginal over and try again.
Nov 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
All in one printer
This seems to be a paper registration problem for the copy function only that is an HP thing Good old HP so innovative and so secretive none of us know whats going on most of the time. Two things to try. Take the stack of paper out of the feed tray and riffle so that it is slightly 'untidy' switch off the device , load the paper, switch on- see what happens. Next look at the software disk- there is usually a fully comprehensive reference manual on there [more than in the book]- check that out then come back.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
