Question about Lexmark X2600 InkJet Printer
My scanner will not work. It has an error code of EC7 flashing across..What does this mean and how can I fix it?
Lights flash, horn blows, wipers jump across windshield,plugged in scanner to check for codes and it just comes back with connection error.
Make sure battery has a full charge, take actual voltage reading across battery posts, everything off. The generic spec for full charge is 12.6 volts or higher. If the battery is down, we can't do any testing.
Pin 16 at your data link connector has to have voltage, pins 4 and 5 are grounds.
Have you tried scanner on different vehicle to see if the scanner works ok?
Oct 26, 2016 | Cars & Trucks
What is scanner error 2 on hp laserjet 3055
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
Jan 12, 2015 | HP LaserJet 3055 All-In-One Printer
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
Error:91:01 how do you get rid of it?
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
May 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
Canon np 6012
Getting error code e0 and 07, and flashing, what is that mean.
Jan 28, 2008 | Office Equipment & Supplies
Error Code 39 with Canaoscan LiDE 25 Scanner
Try RunAs Administrtaor
Try logging in as Administrator (You may need to unhide the 'hidden' Administrator account)
Jan 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
Lexmark X2600 InkJet Printer Logo
369 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
