Question about ASUS Computers & Internet
No sound from p5k3 motherboard
Just built a computer with a p5k3 motherboard and everything seems to be working fine except when I plug in the speakers, I get no sound. I do get sound when I plug in head phones in the front of the computer. Any ideas?
    Genius:
  • 2,785 Answers
Have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
Posted on May 16, 2008
I built my first PC, it powers on and everything seems to be working fine in terms of hardware. I connected the monitor and turned it on and it says no signal what do I do?
with computer power unplugged
pull video card out, then plug in check all connetions between monitor unplug and re plug in just to make sure their properly seated. if video card needed extra power connection check for that, check motherboard power connectors are firmly connected
just recheck your work
Jul 12, 2015 | Computers & Internet
I Have a Uniden UH-015SX and everything seems to work fine except I have no sound coming out, I have tried plugging a speaker in and nothing from it nor the built in speaker. Any Ideas?
hey had the same problem with my 015sx no sound from internal or external speaker... long story short after much playing i found the VOX was on (whatever that is) i pushed the menu button and it showed VOX 8 i moved that till it was off and everthing came good
Jun 27, 2012 | Audio Players & Recorders
P5GD2 Deluxe motherboard in my PC. Recently I installed windows 7 (32bit) and everything seems to work fine except that there is warning that no audio device is connected
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 24, 2011 | ASUS P5GD2 Deluxe Motherboard
Microphone Problems
So people are hearing you but the sound is distorted. Change the mic and keep it farther away.
Feb 09, 2010 | EliteGroup P43T-A2 Motherboard
ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
Jan 28, 2010 | ASUS P5GD2 Deluxe Motherboard
Just installed 2gb more memory on asus p5k3 (6 total) and vista only sees 4gb. Is there a jumper to pull? Thanks, Steve
are u using vista 64 bit cause if ya not thats your problem 32bit platform digitally maxs out at 3 or 4g u need 64bit to go higher
Sep 21, 2009 | ASUS P5K3/P5K (P5K3 DELUXE/WIFI)...
Problem in audio driver for dg31pr
Visit this link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839, select your OS and download the latest sound driver. Also run your add hardware from control panel even if you have to select the device manually.........sodeep
Jun 12, 2009 | Intel DG31PR Motherboard
Having trouble connecting sound on motherboard Jetway pt88bspro
your problem seams to be on the power line...take a good look and see if everything is connected to the supply ..and regarding the Ram problem ...if you recently upgraded..verify the speeds to be compatible and you also might try to choose from BIOS a +O,15 V ...also check ou if your Mobo supports different kinda DDR and DDR2 in the same time if this is the case...or if the module of RAM isn't too large for your model ..but in cases like this ...its ussualy the speed issue...ex..: ya have a DDR2 1G Ram on 800mhz and your pc supports speeds only to 667(666)mhz (check in bios) ..in this case it will run at half of the value...
I hope this will help.....
Mar 29, 2009 | Computers & Internet
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
Computers & Internet Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
