Question about General Electric DHDSR46EGWW Dryer
GE model: dhdsrr46eeoww Dryer The dryer hums whenyou turn the start switch but does dont turn the drum. If i manually turn the drum with the door switch pressed then it begins to work. But then once you turn it off and try again it is stuck. any sugestions to what can be the problem. Thanks
    Master:
    Sergeant:
  • 449 Answers
Your motor is going needs to be replaced
Posted on Sep 14, 2010
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
I have DBSR4EB3WW model number. Last night I was drying clothes, tryed to turn dryer back on , turned the button to right to start clothes and all it would do is make a humming noise. ...
Hello Deborah, it could be a number of things, First the belt, usually if you hear a humming and the drum isn't turning, Its a broken or slipped belt, the hum you hear is the motor turning, But with no belt the drum can't turn other things that can go wrong and cause this are the safety switch located by the dryer door has failed, or a thermostat located in the rear of the machine is bad or stuck if you feel you can check these things , thats cool, just let me know you want to give it a try ,
Jun 16, 2011 | GE DBSR453EBWW Electric Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
Dryer drum will not turn
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jul 20, 2009 | Dryers
Ge dryer model #DHDSR46EE1WW. Dryer will not run- just makes loud humming noise. Replaced the start switch and it still will not run at all. PLEASE HELP!
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Apr 28, 2009 | General Electric DHDSR46EGWW Dryer
GE Dryer won't start without help
YES THE MOTOR IS BAD,TO WEAK TO TURN DRUM ON IT'S OWN,IF YOU GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR MAYBE YOU CAN FIND ONE CHEAP ON EBAY-MIKE
Mar 05, 2009 | GE Dryers
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
82 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
