Question about Cuisinart CWC-1200 Wine Cooler
My Cuisinart CWC 1500 Wine cooler stoped cooling. A local technician said that the "card" needs to be replaced. Where can I buy one for this model? I bought it through Amazon Carla Saravia Guatemala Central America
5 Suggested Answers
  • 32 Answers
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I haven't seen the unit you refer too but it sounds like many others that I have seen. The white stuff is heat transfer compound as used on CPU heat sinks, DO NOT WIPE IT CLEAN, if you have then it will need replacing. Check the fan is running at full speed to cool the heat sink that the plate is attached to. If there is no fan then there isnt much else that can be wrong with it apart from the control circuit, but that seems to be working as you say the plate gets hot.
Posted on Mar 19, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: WE HAVE A CWC-1200 WINE
Unfortunately this uses a "Thermoelectric" cooling system so it needs to be returned to Cuisinart
Posted on Nov 19, 2010
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
The system will not cool and want to replace the refrigeration parts, all else seams to be working fine
I have a Cuisinart Model CWC900 wine cooler that stopped cooling -- the cooling module is bad.
The FIX.
1. First remove the filler plugs from the screw access holes. I did this by tapping the plug off center with a small screwdriver and a small hammer. The plugs popped right out.
2. Use a #10 Torx driver to remove the screws from the holes.
3. The chip on my cooler was a TEC1-12708 made by HB. The part # was on the chip. I found the chip information by doing a Google search on the part #.
4. I found a replacement chip from Custom Thermoelectric. The part # to replace the chip in my cooler was P/N 12711-5L31-09CQ. Cost is about $20. You should specify that the chips that you order should be 'Sealed'. The lady that I spoke with said that the chips last about two years. The people at Thermoelectric were very helpful and appeared to be very knowledgeable.
5. You should apply heat-sink grease to both sides of the chip before installing the chip.
I hope that this helps.
WGD
Jan 22, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Cuisinart CWC-1200 Wine Cooler Logo
132 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
