Question about Hayward Navigator Pool Cleaner
The hoses of my Navigator are twisted every time, I change for a new hoses and the problem still there. What can I do? Thank you Juanluis@caribe.net
  • 3,083 Answers
This following web blog is about this problem, and explains possible causes and fixes and how to test for the problem:
http://www.poolforum.com/pf2/showthread.php?t=1579
The last post has a fix for this problem, it looks like.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 13, 2010
I have three nav vacs and two pools. each pool has a working nav vac and I keep one for a spare. Pool #1- the vac started turning only to the left and in 15 minutes the hose was completely twisted...
This is a common problem with the Navigator. If you grab the part sticking out where the lead hose attaches to the unit, you should be able to turn it fairly easily with your hand. This is the swivel that is supposed to keep the hoses from getting twisted. When you take the unit apart, you will find a large gear plate with teeth that controls the swivel action. All it takes is one leaf or small rock to jam this plate solid and then there is no swivel action and the hose twists. Leslies should have know all about this.
Aug 22, 2011 | Hayward Navigator Pool Cleaner
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Feb 26, 2011 | Hayward Navigator Pool Cleaner
I HAVE HAYWARD NAVIGATOR POOL CLEANER. MY HOSE TWIST UP WHEN IN USE.
With these pool cleaners, it might not be the hose. It could be that your cleaner head has water and is floating, causing the hose to tangle. Check for that problem. If not, it could be that your hose is too long for the pool size that you have. You might need to remove sections on the hose to shorten it.
Feb 15, 2011 | Hayward Navigator Pool Cleaner
The hose on the cleaner gets all twisted up?
Most of the time it is a simple problem that is caused by the way pool cleaners are stored. If you wrap the hose in a coil or around the cleaner when storing it, this is causing the problem. To solve the problem, lay the hose out straight and flat during a warm day. The sun should soften the hose enough to straighten it out. Also, check for obstructions during this time. If the problem continues, you might have too much damage and you might need to replace the entire hose.
Jan 03, 2011 | Hayward Navigator Pool Cleaner
Hose gets twisted all of the time Have replaced almost everything
Try laying the hose out on the ground and stretching it out as straight as you can get it. Let if sit this way in the sun for several hours. You might have a warp in the hose material that is causing these tangles. Allowing it to sit stretched in the sun for several hours will help. Also, try readjusting your return lines. They could be interfering with the pool cleaners pattern and causing the cord to become tangled.
Aug 20, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
May 16, 2010 | Hayward Navigator Pool Cleaner
Hayward navigator (Gunnite pool) does not move. If I hold by hose, in water, suspended above bottom, the unit does not turn. Hose in good shape , valves in correct position. previous to this it was...
you need to install a turbine kit with "a" frames. sounds like your bearings are bad either on the turbine, "a " frames, or both. A set of shoes would be a good idea as well.
Nov 18, 2009 | Hayward Navigator Pool Cleaner
Hi my navigator only turns to the left and after an hour or so the hose is all twisted up and it cant move
This is probally in the gear box in the top of the unit. Most pool shops will rebuuild the cleaner for you for just the price of the parts or a small shop fee. They can check for any other problems at the same time.
Jul 11, 2009 | Hayward Navigator Pool Cleaner
Navigator hose cntinues to twist
I would recommend replacing the gearbox. That's what controls the turning so, if it's not turning correctly, that's the cause. It could also be the hoses. You could change the order of the hoses and that might help.
www.cpo2go.com
Feb 22, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
97 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
