Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Cooltech super xflow not circulating
I have a Samsung Cooltech super xflow refrigerator, however the xflow fan that spins around at the back of the fridge (inside) has stopped spinning, and now the fridge makes a low noise, like it is trying to turn the fan but it isnt working.
what causes it, is it repairable.
the fridge is only 3 and bit years old.
  • Anonymous Mar 26, 2014
    broken defrost heater for fridge
Hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
Posted on Jun 01, 2008
Freezer not freezing as it was
Look for a failure in the defrost system of the unit or a failure of the small circulating (evaporator) fan.
Jul 27, 2014 | Samsung CoolTech Plus / Basic Bottom Mount...
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Does the airflow keep rotating or does it stop in between? My samsung cooltech srv39 works fine but the airflow system does not move since last couple of days. How to fix this?
By airflow do you mean the fan. There is a condenser fan underneath at the back of the unit and there is an evaporator fan inside the freezer behind the rear cover. Both of them should be running anytime the compressor runs. You can see how to test the fan here- http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | Refrigerators
Top is not cooling, sn no cold air is coming into top. Freezer seems to be working
SOUNDS LIKE THE CIRCULATING FAN IS WEARING OUT. THIS PROBLEM IS VERY HARD TO DIAGNOSE BECAUSE THE FAN SPINS BUT NOT FAST ENOUGH TO CIRCULATE CHILLED AIR THRU THE FREEZER AND REFRIGERATOR. THE MINIMUM COST FOR PARTS AND LABOR IS AROUND $300.00. THE FAN IS LOCATED BEHIND THE BACK PANEL OF THE FREEZER COMPARTMENT.
Aug 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My kenmore bottom freezer refrigerator keeps icing up how do i defrost it? model # 596.7182101
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost for labor and material is around $300.00
Aug 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer coils keep freezing up solid. refrigerator side doesn't cool down.
sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. Parts and labor should be around $300.00
Aug 01, 2009 | GE GSS20IBT
Model #RB2155sh. Refrigerator will not cool.
sounds like the evaporator fan motor is wearing out. This problem is very hard to diagnose because the fan still spins, But it does not spind fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost labor and parts is around $300.00. If you try and repair/replace the fan motor yourself, You can find the motor for thaat fan for around$80.00, But this doesn.t count the cost is the other components are worn out,(blade, noise arrestors, mounting bracket). I would let a serviceman make this repair because reaching the electrical connection for the fan is labor intensive.
Jul 30, 2009 | Samsung Refrigerators
Not cold
If you are talking about the refrigerator not cooling, but the freezer is then it appears that the circulating fan is wearing out. This problem is very hard to diagnose as the fan still spins but it does not spin fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost to repair/replace the fan assembly is around$300.00.
Jul 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore bottom freezer ,back of the
replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 28, 2009 | Refrigerators
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
692 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
