Question about Lowrance PC-19BK POWER CORD FOR: LMS-160 MODEL 99-39
I can not find the 99-39 ( PC-19-BK) cable on the internet. any ideas
Wireless internet
if you hav the device, get yourself some internet cable, connect it to the device and log into the wireless device
but before you do.you have to reset the device and check the default ip adress and the password. so after login in you can change it from there..other than that, the device is in a form of DHCP which provide ip address automatically.
Oct 02, 2013 | ASUS Eee PC Seashell 1215T-MU17-BK...
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
Can u get my home page bk on to i explorer please
Open Internet Explorer and click view followed by internet options. The home page address should be displayed in the box.
You may enter in any address to be your home page. Enter it as a web page address. Example: http://www.google.com
Take care!
damnor01
Nov 01, 2011 | Computers & Internet
I have a Eee pc I got from my mom she had internet before that worked fine I show that it is connected to my internet but can not get on line it keeps telling me it cannot display webpage
Please go to network places from you control panel and enable any connections you see available there, also unplug your internet cable and restart the pc, fix it and check.
Jun 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
The problem is wen im having a coversation onlyn wid a person i cant hear dem proper cpz der voice keeps cutting on msn....n wen i try skype dey cant hear me but i cant hear dem coz der voices keeps...
Do have an issue with your audio? Can you play music without any problems? If you are only having problem with skype/msn then you just need a faster internet connection.
Thanks for using Fixya!
May 31, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
How do i get the internet up on my Eee pc laptop
detailsssss... have u ever had internet on it? did you just re-install the system? do you use an ethernet cable? or wireless? detailss..
Jan 13, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Screen turns gray with lots of vertical lines with some pink color as well. Happens sporadically.
Make sure that the cable from your monitor is securely plugged into the back of your PC and that the screws to hold it in place are tightened.
Jul 29, 2009 | NEC LCD195VX-BK (Black) 19" LCD Monitor
Lowrance PC-19BK POWER CORD FOR: LMS-160 MODEL 99-39 Logo
89 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
