Question about Sram Cycling
How do you replace sram force brake hoods - Sram Cycling
2 Suggested Answers
  • 1138 Answers
SOURCE: SRAM FORCE crank lock
If it won't pedal you probably have a broken bottom bracket. This needs to be done in a bicycle repair shop as you need the right tools to disassemble it.You will also need the exact replacement parts as they come packaged with the kit and diagrams for installation. Sorry I'm not more help.
Posted on Jun 05, 2009
My sram force calipers don't open enough and are rubbing my wheels
Try this link:
http://www.bikeradar.com/forums/viewtopic.php?t=12882548&p=17913300
Mar 10, 2013 | Sram Force Caliper Brake 00.5115.030.000
Rear double click SRAM shifting does not work at all hardly. It's supposed to be a smooth transition up/down with single/double click pushes. I can't seem to get it to change it from the two...
The only thing that allows the derailleur to shift to smaller cogs is the spring in the derailleur pulling the cable through all the housing. Therefore if your shifting is stubborn there is too much friction for the spring to overcome. Can be multiple reasons - rust/corrosion/contamination, kinked housing, poor housing ends, frayed cable, etc.
Jul 20, 2017 | Sram Force Double Tap Shift/Brake Levers
SRAM Rival Rear Derailleur stays on the large rear gear when shifting from low to high gears. Sometimes the gears doesn't seem to change at all. I've already taken the bike to Performance bike shop...
adjust barrel on rear mech clockwise till gear shifts click brake lrver for next gear repeat same as before with barrel. If this fails stat from bottom og cassette but adjust barrel anti-clockwise to obtain gears.
Jun 05, 2011 | Sram Rival Rear Derailleur
Sram Red outer chain ring problems. I have been a bicycle mech since 1994. I have a customer with sram red chain rings. He was in outer ring 53T and smallest cog rear cassette. The outer chain ring folded...
im in the industry aswell hmmmmm never heard of any recalls but i know quality speaks volumes of whether i would buy product from which i see an obvious quality based failures ive has similar issues and reported them sram said abuse without even looking at the issue we since have discontinued their line of products hope this helps
Nov 16, 2010 | Sram Force Crankset 53/39
I have just installed my first set of SRAM shifters (2010 Force). The back (right) one did fine; however, the front one (left) shifts fine from the small chainring to the large, but going back down it is...
before you install the cable shift it in the position of small ring ,then insert the cable pull it and tight the screw in the front deraileur(left lever)to it same to the right
Jan 30, 2010 | Sram Force Double Tap Shift/Brake Levers
Juicy 5 brakes
Sram have some instructions here:
(basically they pull out)
http://www.sram.com/_media/techdocs/JuicyCarbon7and5_English.pdf
Hope this helps!
Jan 23, 2010 | Cycling
Jun 04, 2009 | Sram Force Crankset 53/39
Chain rubs inner front derailleur while in lowest gear.
on front derailleurs there should be two small cross head screws one has L(lower) next to it the other has H(higher), you will need a cross head srewdriver, you simply losten or tighten the 2 screws and it will adjust the position of the derailleur to your crankset and it that completely fails then you might need to try a different crankset
Feb 26, 2009 | Sram Cycling
Cycling Logo
458 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
hgpilot
John Egan
John Egan
Are you a Sram Cycling Expert? Answer questions, earn points and help others
