Question about D-Link Computers & Internet
I cannot find the referred to 8 figure ID code on the back of my dlink adsl router (DSL-2740R) and cannot get connected to the internet !!
  • gibsonn Sep 14, 2010
    I know WHERE to look, but there is no 8 digit number amongst the various codes on the label under the router !The label reads thus: P/N: ESL2740REEUS.A1G
    S/N: PVOJ197001932
    MAC ID: 002401A3F158
    H/W Ver: A1
    F/W Ver: EU_ 1.05
    There are very small codes printed on the router itself, namely FCC ID, and IC ID codes.. Neither of thes consist of 8 figures.
    The label codes are duplicated on the outside of the box. I have been able to set the router up and my laptop picks up a strong signal but will not connect with the internet. A message shows when I try saying something about "unable to find server through WLAN port.."....and something about PPPoE . I can't telephone UK help as their number cannot be connected from Spain !! HELP.
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireelss ->wireless security ->wep security Note down WEP code it is your password to connect wifi. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 14, 2010
  • 12,061 Answers
You need to look underneath your router for your PIN code, it is printed under there.
Your user manual is below, look in there for all your answers.
https://m2.ttxm.co.uk/editorial/help/PDF_files/DLink_Pro_Full_guide.pdf
Opening a port for webcam
hi friend
here is the spcifaction of ur router see it
Apr 07, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
My DSL-2730B keeps dropping the internet connection. Can you pleae help me? Thank you, Paul Bryce
Since your using an adsl modem, possible that is a problem with your adsl box or your adsl line. I would suggest you to call your ISP so they can further check your line and also your adsl modem .
You may also contact dlink so they can perform a firmware update to your modem , below is the link for their website.
http://www.dlink.com/corporate/worldwideoffices/?redirect=%2fdefault.aspx
cheers,
KA
Jul 06, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
DSL 2540u internet speed problem
I found the solution for the speed problem.My isp use G.DMT so just put the tick on G.DMT and take out all tick on adsl, adsl+2 etc.
May 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
73 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
