Question about LG 42PX5D 42 in. Plasma HDTV
Tv has no signal
I have a lg tv that is practically brand new. it has no signal after working fine the last few months. i called direct tv and they said there is no problem with the sattellite connection. i tried changing the input and still no signal. ive changed the channels still the same. i did the easy scan and it said unable to find channels. the dvd player works fine when that is turned on. i have it set on hdmi1 for tv which is what it has always been. when i go to change the channel its just snowy.
    Problem Solver:
  • 7 Answers
Sounds like the EDID data has been corrupted in your main board. it can be reprogrammed but most techs will just replace the board. either way someone will have to come out and look at it. it should have a 2 year parts and labor warr on it. call LG cust service and get someone out there.
Posted on Jun 03, 2008
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide -
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
My TV has a white vertical line about 8 in wide on the right side of the screen followed by a few blurry vertical line going toward the center of the screen the left side is fine
More burned capacitors.. You have a center and sometimes a right and left circuit board. If you have to visit the board more than once in just a few months you will have to call the LG tech. You need to replace one of the boards. I tried the self repair route and nearly ruined the TV. Take it from me the tech.
Jul 06, 2015 | LG 60PV250 60 in. Plasma HDTV
I have had a 52" LG TV for about 17 months. I connect several devices (XBOX,CABLE,PC) through a receiver to the TV via HDMI. it worked fine all the time but now all of a sudden all I am getting is a no...
Did you change the HDMI cable? If so, you should check to ensure you have the cable installed so it is running the right direction. It may seem hard to believe but some HDMI cables only allow the signal to run in one direction.
Aug 05, 2014 | LG M5203CCBA 52-inch LCD Flat Panel...
We have had a technika tv for a few months and it was working perfectly. However, we can no longer receive any BBC channels - all of the other digi channels are fine. The set is in one of our guest rooms...
I'm unfamiliar with that precise brand, but if you go into the set-up menu then you should first try to re-install the digital channels from scratch.
If that fails, then the fault is with the transmitter or the reception, not the tv. If you know that the transmission is fine, then check how the tv gets the signal from the aerial. Is the aerial pointing in the correct direction? Are there as few in line splitters and joints as possible in the cable from the aerial to the tv? Have all co-axial connectors been fitted correctly? Digital signals are hundreds of times weaker than the old analogue signals, so it doesn't take much to cause reception problems if your equipment has any faults.
Jul 22, 2011 | Televison & Video
My remote control stops working every few months or so, then starts working again. My warranty goes out this month. Just have a service call and the tech left me another remote, but I'm afraid this will...
The remote interface of the TV died on mine, it was intermittent then it stopped completely. Remote control is fine, it's the remote sensor in the TV itself.
Mar 09, 2011 | LG 50PC3D 50 in. Plasma Television
During the past year, we've had to buy five converter boxes quit.
My DTA1050 worked OK. Then, after a period of non use, it would not work stating no signal. The antenna tests OK on a digital TV.
These things simply die, and Access has our government money!
Jul 23, 2010 | Insignia Digital-to-Analog Converter for...
Black screen no signal
replace the graphics card, ours was going black here and there the last few months then finally it didn't work at all, we just replaced it today and the new graphics card (ati) works fine.
Jun 07, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
LG 8700
May 09, 2008 | LG VX-8700 Cellular Phone
No Signal
Unplug the unit for 24 hours or more, you should be fine after that. No not just turn off, UNPLUG from the wall. Then reset the time and all the stuff should come bacK fine. If it does not then buy a new VCR because to fix this one would require a new microprocessor IC, and that would cost you double on what the VCR cost.
Sep 23, 2006 | JVC HR-A592U S-VHS VCR
LG 42PX5D 42 in. Plasma HDTV Logo
274 people viewed this question
Computer Repairing
Computer Repairing
