Question about Yamaha NS-AW150 Main / Stereo Speaker
How to open. no sound - Yamaha NS-AW150 Main / Stereo Speaker
The hatch wont stay up, makes a loud popping sound and comes down.
sound like the shocks that hold the hatch open have been over extended, thats what the popping sound is when its opened.. replace the shocks and that will keep the hatch open and eliminate the popping sound,
Nov 06, 2012 | 2010 Chevrolet Chevrolet Traverse LT
How do i use my sounds as a ringtone
Open up the options tab when you are looking at the title of the sound. For example, go to your sounds and select, but do not open, the sound you wish to use as your ringtone. Then open the options tab for that sound and it will usually have a button that says, 'set/use as ringtone'. I hope this works, good luck.
May 18, 2011 | Cell Phones
No audio output device found on windows vista, hp
OPEN YOUR "CONTROL PANEL"...THEN OPEN "HARDWARE AND SOUND"
2. LOOK FOR AND CLICK OPEN "DEVICE MANAGER"
3. SCROLL DOWN TO '' SOUND,VIDEO AND GAME CONTROLLER''
4. RIGHT CLICK "SOUND VIDEO AND GAME OPTION"...THEN AN OPTION WILL COME UP SAYING..."SCAN FOR HARDWARE CHANGES"...CLICK IT OPEN YOUR "CONTROL PANEL"...THEN OPEN "HARDWARE AND SOUND"
May 15, 2010 | HP Pavilion dv8000 Notebook
How can I open the Dell AS501 sound bar to replace a broken switch. It doesn't open after the screws are removed.
There is another screw hidden behind the white bar code label, and the whole thing is also glued. You need to use a lot of force to pry it open. It is not worth it to fix it, just buy another off Ebay for around $15 shipped...
Nov 20, 2009 | Office Equipment & Supplies
How would i know if door switch it is not working on my microwave
Use a multimeter and set it to ohms or continuity (the multimeter could have an audible symbol and when you touch both leads should make an audible sound, most of them work this way), if it's a normally open switch you should have continuity (a sound from the meter or a zero or zeros) when the door is closed only and no sound from the meter when the door is open. If the switch it's normally closed you should hear a sound from the meter when the door is open and no sound when the door is closed. If you have a sound from the meter with the leads connected at each side of the switch regardles if the door is open or closed your door switch is bad or if you don't hear a sound from the meter regardles if the door is open or closed the door switch is bad.
Apr 04, 2009 | General Electric Microwave Oven
No sound
Hello hassahabi, what I think happened to your sound is this. When the apple iTunes software installed you allowed iTunes to take over all your sound files within the system. To gain back your system sounds try this: Open windows Explorer & left click once on C:\
Once high-lighted, left click on Tools & left click the tab " File Types ". Scroll down the list to, WAV.
Left click once on WAV - wav sound. The sound file should open with Windows Media Player & not to ipod or iTunes. Click the, "Change" button. The "Open With", window will open. Find, Windows Media Player in the list. Left click once on it & than click OK. Most of windows sounds are located in the C:\Windows\Media folder. I suggest you also set MID to open with Windows Media Player.
Once finished close all opened windows & restart your system.
When windows finishes loading open the sound icon by first double left clicking the sound icon. Check that the wave slide bar is all the way up! Close that window. Now right click once on the sound icon & left click "Adjust Audio Properties". Sounds and Audio Devices Properties window will open.
See if the play button is no longer grayed out.
If it is grayed out you'll have no choice but to uninstall the apple software to free your system sounds.
Next round of ipod iTunes installation watch your screen's & choose not to allow iTunes to control, *.wav sound files.
Good luck hassahabi!
Run into trouble? Post back here.
Mike
Nov 12, 2008 | ASUS P4S8X-MX Motherboard
Cant get any sound on my aspire5920
- Open the Control Panel
- Open Sounds and Audio Devices
- Open Hardware
Look for a device with some name and model number with 'Audio' behind it.
This will be the maker of the sound hardware.
Close the two latter functions and open System
- Open Hardware
- Open Device Manager
- Locate Sound, video and game controllers and open
- Locate the name you found previously
- Highlight and delete ( or uninstall) it
Restart your PC.
This should force Windows to recognize it again and look for and hopefully find the device drivers for it.
It is possible that as often happens, Windows just shot (corrupted) the device driver for the heck of it.
If this doesn't work, you need to run an online scan of your system or run your current AV program to see if something is tinkering with your sound facilities.
Sep 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
I dont have sound in my pc
check the device manager and see under sound, video and game controllers folder if the sound card drivers are installed properly. it might just be a re-installation of the drivers for your sound card.
Aug 25, 2008 | Edirol UA-4FX External Sound System
Can u help us m8
contact the dealer of where you bought your stereo...or maybe the sony company...:)
Dec 13, 2007 | Sony CDX-M610 CD Player
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Oct 18, 2007 | Sony CDX-M630 CD Player
Yamaha NS-AW150 Main / Stereo Speaker Logo
23 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
