Konica 7145 i have an error message 0006 I have replaced drum in drum assy. it gave me an f26-3 error message performed L detection now it gives 0006?
Check Toner control sensor board, on drum unit behind drum, is clean, try L-detect then, try it a couple of times. If that fails you will then have to change developer, and perform L-detect.
Posted on Sep 14, 2010
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub 7145 Copier
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Konica minolta magicolor 2350dl drum replacement
Was the new one new? Check the medal connectors located on the image unit anything medal and clean with alcohol and all connectors on the assy. the image unit goes in reseat properly Third party do not work use OEM
Apr 11, 2012 | Minolta magicolor 2350 Laser Printer
My printer is giving me a message as follows drum error- take out drum and slide blue tab from side to side a few time. where is the drum?
When you open the door in front pull out the drum/toner assy. You will see a blue piece on top left side. It will slide right and left. Do it 5 times. Leave it all the way to the left and reinstall it. steven 818-888-0006
Mar 15, 2010 | Brother MFC-7820N Printer
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Aug 04, 2009 | Konica Minolta Di1610 Copier
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
265 people viewed this question
jasbo
jasbo
